6 meter
Someone sent me a list of radio frequencies and it list 6 meter armature radio freq. as aircraft, I have had a general class license for over 40 years and would like to use a 6 meter radio but can’t find any.
RE: 6 meter
If you go with 2.4, you won't have frequency concerns. I don't have to worry at my field, only 5 or 6 people come to fly.
RE: 6 meter
Usually 6meter modules are special order, but they do exist. I had a Futaba 8UAP on 50.880, and used it for many years. Upgraded to 2.4 recently. My club didn't even have tags for 6 meter. You can usually find the 50MHz versions in the higher end (10/12 channel) radios, but special order for an 8 or 9 channel TX.
Hope that helps. Personally- after flying 50MHz for several years, and then switching to 2.4GHz, I've noticed no difference in functionality. No glitches, although I had several with the 50 MHz TX, but that might have been a result of the RX itself. |
| All times are GMT -8. The time now is 01:50 PM. |
