RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Planes No One Should Have !!! (https://www.rcuniverse.com/forum/beginners-85/8638928-planes-no-one-should-have.html)
chashint 04-01-2009 02:39 PM
The thread for planes everyone should have was popular so here is the counterpart.
What models are not worth the time or money to even try them out ????
perreback 04-01-2009 02:50 PM
RE: Planes No One Should Have !!!
This one seems like a bad idea: :D
http://www.ctie.monash.edu.au/hargra..._first_500.jpg
alfredbmor 04-01-2009 03:55 PM
LOL
I don't see where I can bolt any of my Saito engines in there.
playntraffic 04-01-2009 03:56 PM
Hobbyzone Firebird, Aerobird, etc. All the Firebird variants like the Challenger, Swift, etc
dash008 04-01-2009 04:01 PM
1 Attachment(s)
Great Planes PT40 with the "A" trainer wing. I build one for my first plane and the manual "strongly recommended" building the A wing. so not knowing any better, that's what I did... Ailerons were ineffective on this plane so it was very hard to learn on. Also, it would balloon like crazy with all that dihedral. It's probably fine with the "B" wing, but instead of building a new wing I just bought a $70.00 Tower Trainer and learned on that.
Sharku 04-01-2009 04:11 PM
one of these http://www.aerofiles.com/walden.jpg
Murdoc 04-01-2009 04:32 PM
vmar planes:)
CGRetired 04-01-2009 04:36 PM
S.P.A.D. s
Mode One 04-01-2009 04:51 PM
Since 1968, I've never run across an R/C airplane that I felt "No one should have". Some where better then others, some where easier to build then others, some where better looking then others and some had better instructions then others.
bruce88123 04-01-2009 04:59 PM
ORIGINAL: Mode One
I have similar opinions. Many planes that I personally wouldn't own but wouldn't care if someone else bought them.:D
hugger-4641 04-01-2009 05:38 PM
ORIGINAL: playntraffic
I disagree to some extent. I have the Freedom ,it is a tough bird and flies great when trimmed right. But it should not be marketed as a "begginer" level plane like it is. It is hard to get trimmed correctly due to small control surface and the anti crash is useless. By the time your are skilled enough to get this plane in the air, you don't need the anti crash. But I wouldn't classify it nearly as bad as some cheap electrics like some of the "Fly zone" planes.
beau0090_99 04-01-2009 06:18 PM
Great Planes Tutor.
The recommended power system is a joke. It is a kite without a string and the wing is so difficult to keep flat that the ailerons buckle. Don't loop it unless you have glassed the center.
Curtis
MetallicaJunkie 04-01-2009 06:24 PM
An Italian Bomber WWII era....almost every video i see of one has some kind of crash involved
http://www.youtube.com/results?searc...bomber+rc&aq=f
DavidAgar 04-01-2009 06:28 PM
One word......Duraplane. Every flight is an adventure in frustration.
daveopam 04-01-2009 06:42 PM
I had a Hobbico Extra 300 ASAP back in the early ARF days. It was a piece from top to bottom. Lasted 1 flight. The CG was printed on the side of the fuse. I found out later the CG mark was way to far aft. I don't know if more than one batch ever hit the shore.
David
MajorTomski 04-01-2009 06:56 PM
ORIGINAL: Murdoc
vmar planes:)
Ditto
Gray Beard 04-01-2009 06:59 PM
Dave, any of the early ARFs were a risk, some of the things I have seen that happened with/to them!! I still find a lot of problems or mistakes with the ARFs today but they sure have gotten better. {{For the most part}} I know a number of planes I don't want or like myself but if I mention any of them there are a lot of people that love them that will argue the point. I even know people that loved the Duraplanes and some other total crap that has been put out over the years. I'm not a big fan of the Cub but if you fly then someday you will have one.
Phoenixangel 04-01-2009 07:19 PM
1 Attachment(s)
megatech arf or rtf
yikes....
my first plane was one of these awful cigarette pack cellophane covering, no support for anything, leaky fuel tank ( im serious) and the simple seven system is a bunch of holes for fuel to enter the wood, and the instructions were almost nill one photocopied b/w front page
jrcaster 04-01-2009 09:17 PM
ARF's and ARC's period. Building is a very important part of the hobby. If you don't have time to build it, then you don't have time to fly it.
carrellh 04-01-2009 09:36 PM
ORIGINAL: jrcaster
I totally disagree with this. Whether they do or do not "have time" for building, some people simply do not like building models but they do like flying them.
ChuckW 04-01-2009 09:46 PM
I like to build from time to time but a nice ARF is great to. For those that say they "just aren't" as good, take a look at some of the latest stuff from the more reputable manufacturers. it is amazing.
I like driving my truck too but I didn't build it from the ground up. Is that OK?
fly boy2 04-01-2009 10:02 PM
ORIGINAL: CGRetired
S.P.A.D. s
Hold on now; Which ones? My Debonair is a dream to fly. Thingin on building one this year.
MetallicaJunkie 04-01-2009 10:51 PM
ORIGINAL: jrcaster
ARF's and ARC's period. If you don't have time to build it, then you don't have time to fly it.
-1
jib 04-01-2009 11:18 PM
ORIGINAL: CGRetired
S.P.A.D. s
Whoa there CG!!!!
I love our SPAD Debonair. It's a sweet flying plane, a great trainer and a fun casual plane. I also love the fact that the pressure is off when learning to fly with a SPAD. If you crash, chances are it'll fly again without any surgery.
FYI - We fly balsa and plastic.
Then again, this is stricty an opinion poll and I think you are just yanking some chains.
Jack
Tom Nied 04-01-2009 11:30 PM
yeah, don't build a SPAD Debonair with a straight wing and as Taildragger, it's a dog. I've been flying mine for at least three years now and it may not be the lightest plane in the 46 class, but I've had a blast with mine. Sure it doesn't fly as good as a previous Avistar did, but it is quite rugged. It will loop, roll, fly inverted and land fairly easily. I'll always fly it when I wouldn't even consider flying balsa. It's been windy and I'm flying when others haven't even come out to the field. It sure is a dog, but I'm flying. ???
