24V Starter
I have a 10yr Sullivan 24v starter that is very worn...the shaft wobbles even though it isnt bent...like it needs bearing....
What other alternatives are there for using 24 volts....i built my flight box around 24v and would like to continue using both batteries |
RE: 24V Starter
I would send it to sullivan for repair.I have had good luck returning items for repair and have found that the top names usually repair them for miminal cost and return it in like new condition.good luck
RE: 24V Starter
Most of our model engine starters will run on 24 volts without problem
http://www.sullivanproducts.com/StartersContent.htm |
| All times are GMT -8. The time now is 04:20 AM. |
