spinner installation
Can someone please provide some detailed instruction as to how an aluminum spinner and prop adapter are installed? Lots of pieces (some are left over I'm sure) but zero instructions with spinner and prop adapter. Engine is Magnum .91 two stroke spinner and prop adapter are Tru Turn.
1. Centering the backplate? Bushing included with spinner is to small for engine shaft. Purchase a larger one? Are there any tricks or bushing substitution ideas? 2. Thrust washer that came with engine. Is it used or is the steel washer that came with prop adapter substituted? 3. Prop nut and jam nut that came with engine. Where do the adapter nuts fit in? Thanks |
RE: spinner installation
Here's where you can buy the bushings only to center the back plate
http://www.truturn.com/cgi-bin/store...aparts&maxp=30 Here is where you can buy the proper bushing and nut to go with your engine http://www.truturn.com/cgi-bin/store...2a&ppinc=adapt Engine thrust washer that came with your engine, spinner back plate, prop, prop washer that came with your engine, Tru-Turn nut. Spinner is held to the nut with a screw |
Thanks a bunch for the info!
ORIGINAL: w8ye Here's where you can buy the bushings only to center the back plate http://www.truturn.com/cgi-bin/store...aparts&maxp=30 Here is where you can buy the proper bushing and nut to go with your engine http://www.truturn.com/cgi-bin/store...2a&ppinc=adapt Engine thrust washer that came with your engine, spinner back plate, prop, prop washer that came with your engine, Tru-Turn nut. Spinner is held to the nut with a screw what sized spinner would work well (from tower) |
It depends on your plane.
I would think a 2" would be minimum with that engine A 2 1/2" would look good Try to get the spinner with the metal back plate http://www3.towerhobbies.com/cgi-bin...?&I=LXBMY8&P=7 |
lol
i just bought that spinner for a .40 mag my friend gave me. ill check again but i dont think the prop (14x6 or 15x4) would fit in the "cavity". also how would i ream it, (i have a prop reamer, use that?) |
I use a rat tail file to make the spinner clear the prop
| All times are GMT -8. The time now is 02:49 PM. |
