RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   dx7 and aileron switch (https://www.rcuniverse.com/forum/beginners-85/8857374-dx7-aileron-switch.html)
confuzshuz 06-16-2009 05:50 PM
I've switched to spektrum from airtronics and I'm getting used to the differences.
What's the proper way of setting up the ailerons with the dx7 and servos? Am I supposed to keep the flap switch in the middle then set up the servos or keep the flap switch on normal then set up the sevos?
I currently have my flap system on radio set up at Norm: 0%, Mid: DN50%, Land: DN75%. I set it with the flap switch on normal then set up the servos. If I leave it on Norm: UP100%, Mid: 0%, Land: DN75% and set up the servos with the switch on mid, I get spoilerons when I place the switch on normal. I'm not sure of the proper way to set up the ailerons.
Thanks in advance</p>
N429EM 06-16-2009 05:58 PM
RE: dx7 and aileron switch
If you want spoilerons, you need to set the switch at "mid", and set up your servos for neutral.
For flaperons, change the settings to your prefered settings, before you put your servos at neutral, with the switch at 'Norm".
I prefer to use flaperons, but it never fails, I forget to change the settings. And, then I wonder why I can't get my ailerons to perform properly.
Good luck,
EJ
confuzshuz 06-16-2009 06:53 PM
thanks for your reply. I'm used to using flaperons, myself. My previous airtronics radio was preset a bit different and that's what I was used to.
N429EM 06-17-2009 12:38 AM
ORIGINAL: confuzshuz
You're welcome. Did you get it set up the way you want?
EJ
confuzshuz 06-17-2009 12:43 AM
Yes, I did.
Thanks again.
