14 channels?
Once you've covered the basics like Ailerons (2 channels), Elevator, Rudder, Throttle, add Flaps, Gear, Smoke and a Drogue Chute you would have a pretty fancy plane and still have 5 channels to spare.
So what do you use a 14 channel radio for? |
RE: 14 channels?
14 channel radios offer virtually unlimited programming capabilities; you may not use nearly all of the channels, though some may.
Large (like huge) scale planes have several servos on each aileron, multiple servos on the rudder, etc. Add flaps, bombs, smoke, lights...you get the idea. I was talking to a top pilot at a pattern meet who used a 12 channel radio. I think there were only 6 servos in his plane but he wanted and uses some of the very advanced programming features only found in high channel radios. By the way, sushi is absolutely incredible. I was just about to head to the restaurant and get some until I realized the time [&o] |
RE: 14 channels?
I see a lot of the 12 and 14ch radios at IMAC and 3-D events then at the IMAA events, IMAA is giant scale and like Joe mentioned, big scale planes can use up a rado really fast. One of the pilots I know was showing me his 14 at the local IMAC and it was just way more then I would ever use. Then again I used to say that about the 9 and 10ch radios and I can use up my 9 in a hurry with one of my big planes. I have been told that some of the heli pilots are using the big radios a lot but I haven't been to an event so don't know.
Not something a weekend pilot would need. |
RE: 14 channels?
I came up with 15 possibilities in a minute or so. I'm sure I missed some.
2 aileron 2 elevator 1 rudder 1 throttle 2 flaps 1 retracts 1 bomb bay doors 1 bomb release 1 sliding canopy 1 drag chute 1 smoke 1 ignition kill switch 15 total |
RE: 14 channels?
1 Attachment(s)
This plane uses 14 channels.
1- Elev 2- Aileron 2-Flaps 1-Rudder 2-Engine 1-Retracts 1-Wheel Brakes 1- Smoke 1-Air Brake 1-Nose wheel steering 1-RX Batt (back-up power) ... And the dedicated primary RX battery port. |
RE: 14 channels?
Add choke on a big gas engine
On big models using 2 channels slaved together for rudder and nose wheel steering is common. |
RE: 14 channels?
ORIGINAL: gaRCfield 14 channel radios offer virtually unlimited programming capabilities; you may not use nearly all of the channels, though some may. |
RE: 14 channels?
Thanks, guys!
As a follow up question... Why would you use multiple channels for functions like flaps and elevators? I understand if you are turning ailerons into flaperons but even there you are using two channels for two functions. But if you need two servos on an elevator, what do you gain by utilizing two servos and two channels vs two servos and a Y jack? As for sushi, I love it too. I also enjoy offshore fishing, so somehow the username seemed appropriate. :D |
RE: 14 channels?
Using independent channels for servos (on a good computer radio) allows you to independently adjust the center, end points, direction, differential, and even speed of each individual servo, so that all surfaces work in unison.
Using Y-jack does not give you this kind of control. Another cool thing you can do with a high end radio is adjust the 'curve' of the servo/control surface. The servo arm moves in a circle and thus the speed that the control surface travels is not linear. With a fancy radio you can change that - make it linear or any shape you want (smooth from low to high, more sensitive at mid, sensitive at low and mid but not high, etc.) |
RE: 14 channels?
Another channel that some people like to use also is one for nose gear steering. Meaning, one channel for rudder and another for steering. You mix the steering back to the rudder. Makes triming planes that take off and land fast sooo much easier because you can trim both controls independently.
Cheers. |
RE: 14 channels?
ORIGINAL: SushiSeeker Why would you use multiple channels for functions like flaps and elevators? I understand if you are turning ailerons into flaperons but even there you are using two channels for two functions. But if you need two servos on an elevator, what do you gain by utilizing two servos and two channels vs two servos and a Y jack? > regular ailerons > regular flaps > full span ailerons (flaps acting as ailerons) > crow/butterfly (flaps down, ailerons up) All of this is often done on the Hangar 9 Ultra Sticks With elevators on two channels, and the right transmitter, you can make the elevators work in conjunction with the ailerons. The Bruce Tharpe Delta Vortex has dual rudders. With them on two channels, and the right transmitter, they can be used as 'air brakes' |
RE: 14 channels?
ORIGINAL: carrellh ORIGINAL: SushiSeeker Why would you use multiple channels for functions like flaps and elevators? I understand if you are turning ailerons into flaperons but even there you are using two channels for two functions. But if you need two servos on an elevator, what do you gain by utilizing two servos and two channels vs two servos and a Y jack? > regular ailerons > regular flaps > full span ailerons (flaps acting as ailerons) > crow/butterfly (flaps down, ailerons up) All of this is often done on the Hangar 9 Ultra Sticks With elevators on two channels, and the right transmitter, you can make the elevators work in conjunction with the ailerons. The Bruce Tharpe Delta Vortex has dual rudders. With them on two channels, and the right transmitter, they can be used as 'air brakes' Okay, This is cool stuff! I think I understand now. You don't have to be controlling 14 discrete functions, but you have the flexibility to control or link controls in unique ways. So who here is ready to drop $2,200 on a Futaba 14MZ? [sm=tongue_smile.gif] |
RE: 14 channels?
A guy at my field has the JR 12ch radio. It's really freaking nice[sm=spinnyeyes.gif] However I would not feel right with one in my own hands. I could feel good about owning a 9 or 10ch, but not a 12 or 14. I honestly don't think I will ever need the functions associated with a 12-14 channel radio (of course that's my hobby and my own take on it);)
RE: 14 channels?
IMO users of radios more than 6 channels - its not what they need its what they want.
RE: 14 channels?
ORIGINAL: Alex7403 IMO users of radios more than 6 channels - its not what they need its what they want. |
RE: 14 channels?
ORIGINAL: Alex7403 IMO users of radios more than 6 channels - its not what they need its what they want. You mean to say users of 'basic airplanes'.. not radios, need no more than 6 channels. FYI- 'Most' people who have to buy a 12/14 channel radio don't really want to buy it... They actually need to buy it for the airplane's system requirement. ... Notice I said "most" people, not all people ;) |
RE: 14 channels?
I'm looking at gas airplanes yak's, extras now and being surprised those big DA-100 powered airplanes need only 4-6 channels.
sure for jets you can invent even 20 channel needs... and yes the the programing capability of those high end radios is amazing, i'm just trying to justify for myself a purchase of a higher end radio. Alex |
RE: 14 channels?
unless you get into serious IMAC/pattern/ect (if you get that good, to a point where even little things make a big difference, you will be flying 2500+ planes and the tx wont look so expensive)
or can drop 4000+ on a really big airplane that needs that many channels. their is not really a way to justify it. |
RE: 14 channels?
ORIGINAL: Alex7403 I'm looking at gas airplanes yak's, extras now and being surprised those big DA-100 powered airplanes need only 4-6 channels. Guys flying that kind of equipment need an airborne power supply to feed those power hungry servos. A Power expander like Power Box and the like is what is in place between the RX and the servos. These 'expanders' can split channels to give you "more RX channel ports" while using the basic 6 or 8 channel RX. |
RE: 14 channels?
My point is that i rather have less switches to clean and brake on my Tx but keep the high end radio programing capabilities on a 6-8 channel Tx.
RE: 14 channels?
trust me, at first you wont use the switches but later on they will really come in handy
their isnt a 4-5ch (that i know of) that has 7-8 ch programming capabilities. the reason being all of those switches are used to turn on and off those fancy mixes and whatnot that you will be useing. also why would you worry about breaking them if you would never use them to begin with (but you will use them). they are a lot harder to break than you think get a decent 7-8 ch radio i would recommend a futaba 7c. i would stay away from 6ch radio's because they do not have the extras a 7+ radio has. these really come in handy. |
RE: 14 channels?
There really is a difference between 6 channel radio programming and 7 channel radio programming. I would be a little surprised to find a pilot flying a Yak with a DA100 who didn't really want a 7, if not 10, channel radio.
I had a 6 (even an 8) channel radio, and it was incapable of some functions that are 'basic' on larger aircraft (dual elevator setup, dual aileron setup, simple knife edge mix, etc.) I'm not starting the argument here that one needs X amount of channels to fly a plane, but you (I) get to a point where you expect certain things beyond the capabilities of a 6 channel radio. Best thing is to figure out what you really want before buying a new radio. |
RE: 14 channels?
ORIGINAL: jimmyjames213 unless you get into serious IMAC/pattern/ect (if you get that good, to a point where even little things make a big difference, you will be flying 2500+ planes and the tx wont look so expensive) or can drop 4000+ on a really big airplane that needs that many channels. their is not really a way to justify it. |
RE: 14 channels?
ORIGINAL: Alex7403 My point is that i rather have less switches to clean and brake on my Tx but keep the high end radio programing capabilities on a 6-8 channel Tx. HOw many big planes like the 40% YAK have you ever seen flown with a small radio. Half of the guys I fly with are flying giant scale and the 9ch is the number one choice for sport pilots. People flying IMAC tend to go bigger. You could set up a big plane with a small radio using Match boxes, not Y-harness!! You would be missing a lot of the programs. When you break away from the smaller planes you will want the biggest radio you can afford. And a big NO, I can never see myself spending the money for a 12 or 14. I don't have the type of money you need to get into the planes that will require a radio that big. I had to use a match box for my 30% Extra when I ran out of room in my 9ch though and I'm only running single aileron servos. If I was running four then I would have needed another match box. Just for grins go into your radio and set Expo on your throttle, just see if you can do it. That's just one little program a lot of us use.;) |
RE: 14 channels?
Even on my fairly simple Waco Biplanes that does not have flaps, or retracts, I use the following:
2 Elevator 1 Rudder 1 tail wheel 1 adjustable horizontal stabilizer 1 throttle 2 aileron That's 8. I have used 12 on some models, and could have use 14 if I had not used Y harnesses. You might wonder why I use a seperate servo and channel for the rudder and tail wheel, but the tail wheel only travels 40% of the rudder movement. |
RE: 14 channels?
Ok, I've watched this thread progress and I thought I would jump in and add my 2¢ worth. I've been in the hobby for close to 14 years now and I've never needed more than 6 channels on a radio until I started doing reviews. I needed more channels for some of the planes I was reviewing. So what's my point here? It's that not everybody is going to need to buy a 8, 9, or higher channel radio to fly with. Yes, I totally understand for some that are flying giant scale, pattern, warbirds, or other specialty type planes where having higher channel radios is almost mandatory. But for the MAJORITY of people that would be classified as "sport flyers" those types of radios are a waste of money. Not trying to point fingers here but to drop a few names like Minnflyer, CGRetired, Bruce88123, and myself all consider ourselves to be sport flyers and are perfectly happy with a 6-7ish channel radio. These radios offer more than enough features for what we need to do in our everyday flying.
Like I said, I have higher channel count radios for reviews. I have a JR X9303, and Futaba 9C (with 2.4 FASST module), and now the new Airtronics SD-10G 2.4 radio, but when I am out flying my own planes I have all of them on my good old Airtronics RDS 8000 2.4 radio. For my sport flying I don't need anything more than "basics" that a computer radio offers and higher end radios would be a waste of money for that type of flying. So what kind of planes am I talking about that I have on this radio that are "sport" planes? Great Planes Slow Poke, Great Planes Cherokee, Great Planes Escapade, planes built 60 size Kaos, Model Tech Mach Racer, and a Great Planes Cub. And with the new 6 channel receivers that Airtronics is putting out I'll be adding two park flyers to this list as well. My point here is that I'm just trying to show that it's not automatic that every pilot needs a high channel count radio. For many that will fly they may find that they NEVER need over 7 channels to fly with. For those that do advance to other planes that need the high channel count radios there is absolutely nothing wrong with getting what you need, but for those of us that just like "lazy sunday flying" spending that kind of money is a waste. Oh, and if you ask my opinion on what is the best right now in this category for us "sport flyers"? Right now it would have to be the Airtronics RDS 8000, it's currently priced at $139 with one receiver (no servos). This is an 8 channel 2.4 radio priced at an entry level price. However, the Futaba 7 channel FASST radio, and the Spektrum DX7 are both great radios for those of us at this level as well. Ok, that's my 2¢ worth here. Just throwing out a bit of reality to show both sides of the issue. Ken |
RE: 14 channels?
I know most people don't need more than what a 7-channel radio can handle. In fact, I won't for a while. 2 ailerons, 2 elevators, 1 rudder, 1 throttle for a 50cc plane. That's only 6 channels. In fact, some 100cc planes can use those same six channels. I have yet to see a 6-channel radio that allows you to run dual elevator servos. Nor have I seen one that can handle good knife-edge mixing capabilities. They also normally have ONE programmable-mix, and that's just not enough for me. I have a 10CAP (more than enough), but am using 3 p-mixes and a ton of pre-programmed mixes. I don't really fly big planes (biggest I've got is a 60" Aeroworks Extra 60-90), but I like playing around with the programming. I enjoy getting my planes to fly differently using different mixes. I used almost half of my transmitter's programming capabilities on a Pulse 40. It's a VERY simple plane, but I had it flying like a 2M pattern plane before I was done with it. That thing had NO bad habits that I didn't program out. It would KE hands-off out of sight, vertical rolls wouldn't go off track, I had spoilerons and flaperons programmed in for when I need them, aileron differential, EVERY bad habit (of the few it had) were non-existent by the time I was done. So, as has been said before, programming capabilities are normally a bigger deal than actual number of channels.
The 14MZ automatically programs multi-point mixes with the push of a button. It will also play an audio track when you do certain things, like you can get it to tell you when your gear is up or down, you can get it to tell you what percentage of flaps you're currently at, low/mid/high rates announcements, announcements of time left, etc. You can also put a picture of your actual plane on your screen for each model, helping you identify them. It's also the coolest radio out there (touch screen, color screen, etc) so a lot of people get it simply for the cool factor. However, 14 channels can be used quicker than you'd think. 3 per aileron 2 per elevator 4 on rudder throttle choke ignition kill smoke That's 18 channels. You can (or could, anyways) add up to two MPDX-1 Multi-Channel Proportional Decoder and expand your stock 14-channel Rx to 28 fully proportional channels. Now THAT'S a lot...but I'm sure Mac Hodges (for example) could find a use for all 28 channels. Plus, in scale planes, there are functions you'd never think of. Someone here on RCU built an F-14 with a functional mid-air refueling valve. |
RE: 14 channels?
ORIGINAL: SoCalSal ORIGINAL: jimmyjames213 unless you get into serious IMAC/pattern/ect (if you get that good, to a point where even little things make a big difference, you will be flying 2500+ planes and the tx wont look so expensive) or can drop 4000+ on a really big airplane that needs that many channels. their is not really a way to justify it. overdoing requires no justification :D but on the topic, the only reason i could see a everyday sports flyer needing more than a 8ch radio is to expand the amount of models it can hold so you dont have to carry around more than 1 tx. also for the module capability to switch between 2.4 and 72, and possibly for more 3 position switches (not really needed but good to have) |
RE: 14 channels?
ORIGINAL: jimmyjames213 ORIGINAL: SoCalSal ORIGINAL: jimmyjames213 unless you get into serious IMAC/pattern/ect (if you get that good, to a point where even little things make a big difference, you will be flying 2500+ planes and the tx wont look so expensive) or can drop 4000+ on a really big airplane that needs that many channels. their is not really a way to justify it. overdoing requires no justification :D but on the topic, the only reason i could see a everyday sports flyer needing more than a 8ch radio is to expand the amount of models it can hold so you dont have to carry around more than 1 tx. also for the module capability to switch between 2.4 and 72, and possibly for more 3 position switches (not really needed but good to have) If someone wants to give me a nice new 14 I'm sure I would start growing into it too, just no way I would ever buy one. |
| All times are GMT -8. The time now is 07:09 AM. |
