receiver battery
I just purchased a 2000 mah 6v receiver batter. after charging, the volt meter says 7.2 volts....will this mess up my receiver?
RE: receiver battery
No, this is normal.
i have been using a 6v battery for 6 months on mine and have had no problems at all (futaba 2.4ghz), an best of all servos working quicker, a big difference. wont buy a 4.8v pack again!.
Most receivers can handle 6v batteries with no problem.
There are some servos, mostly digital, that can't. Check the specs on your equipment to be sure. |
In case you didn't know, A five cell battery reading 6V could be anywhere from 80% full to almost drained. 6V is the nominal voltage, so the voltage fully charged is around 7V.
| All times are GMT -8. The time now is 02:20 AM. |
