RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   To solder or crimp (https://www.rcuniverse.com/forum/beginners-85/9196538-solder-crimp.html)
goirish 10-23-2009 03:17 PM
To solder or crimp
1 Attachment(s)
see the pictures below. These are male bullets 3.5mm that have what looks like black shrink tubing already installed. It seems like you cannot remove them. Do I crimp this or will in fact the black tubing slide off. Thanks, got talked into trying some indoor electric and like the dummy I am, I said OK.
el_xero 10-23-2009 03:32 PM
RE: To solder or crimp
Thats odd, i've never seen them sold like that before.. I'd normally solder bullet plugs.. however, what is under that shrink wrap? Is it wire or open hollow and cylindrical. If its wire I'd cut out the heat shrink remove the wire thats inside of the plug and put my own in.. If it's the other way then its probably designed to be crimped.
goirish 10-23-2009 03:36 PM
ORIGINAL: el_xero
It is open. Really looks like it is suppose to be crimped.
kristj179 10-23-2009 03:38 PM
yes can any body help i just purchased a flight kit from tower hobbies. i need to change the servo horns or arms noy sure what they are called? the servos are s3004 servoes for the arelons sorry about the spelling a single arm horn
goirish 10-23-2009 03:40 PM
I just googled Great Planes and these are connectors that the motor 2mm plugs into and the 3.5mm end plugs into the ESC. Wrong part.
opjose 10-23-2009 03:53 PM
ORIGINAL: kristj179
Take this to a NEW thread.
And supply more details.
What "flight kit" did you purchase?
Please give the link to the web site item.
For what plane?
Why do you need to change the horns?
cappaj1 10-23-2009 04:26 PM
1 Attachment(s)
ORIGINAL: goirish
If you have bare wire, this what you need to solder them to that will slip into those plugs - 2mm male bullet connectors. About 3/4 of the way down on this page:
http://www.electrifly.com/miscproducts/connectors.html
pic:
goirish 10-23-2009 04:38 PM
I am going to return them to the LHS and get the proper ones. They were picked up for my by a friend. (Hummmmmmm!!! maybe he is not a friend, ya think)[sm=72_72.gif]
Nahhh!!! he is a friend.
aerofly0610 10-24-2009 07:40 AM
those are adapter plugs not plugs you crimp/solder
goirish 10-24-2009 07:50 AM
ORIGINAL: aerofly0610
On my way to the LHS to replace. The bummer is1 1/2 hr drive. For a $6.00 part. [&o][sm=angry.gif][sm=disappointed.gif]
