RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   cg for stick (https://www.rcuniverse.com/forum/beginners-85/9198067-cg-stick.html)
kenncarleton 10-24-2009 08:07 AM
cg for stick
Hey all got a old used blasa usa stick 40 the old style with 3 ch set up look for some one who know the cg points for this plane.. I am thinking about remaken about 8 of them for the local cubscout troop ... thanks in advance
~kenn
proptop 10-24-2009 08:57 AM
RE: cg for stick
I believe that has a constant chord wing?
If so...just measure the chord (from the wings Leading Edge to the Trailing Edge ) and whatever that measurement is, make a mark about 25% of that amount back from the L.E. (Leading Edge )
An acceptable range would be 25 to 30% back from L.E.
Lnewqban 10-24-2009 09:13 AM
RE: cg for stick
You can take some measurements off your model and input the data at this proven on-line calculator:
http://www.geistware.com/rcmodeling/cg_super_calc.htm
