motor mount
does anybody know if the mounting bolt pattern for an OS .40 la is the same as an OS .46 la.
RE: motor mount
http://manuals.hobbico.com/osm/40-46-65la-manual.pdf
Looking at the manual's 3-view drawing (page37) it appears that the mounting pattern is identical for both engines. Ken |
RE: motor mount
thanks bud
RE: motor mount
Yep should line up perfectly
RE: motor mount
There are 2 standard mounting dimensions. One is the width or lateral distance between the center of the holes (dim A) and the length or longitudinal distance between the centers (dim B). Most manufacturers publish this stuff (especially OSfor all current and discontinued engines). Dim A for both engines is 1.59 in. and Dim B for both is .69 in. Ijust hate it when they use standard measurements rather than metric! In metric it's A - 44 mm, B - 18 mm.
www.osengines.com/engines/engine-specs-discontinued.html is the OSspec page with all this stuff. |
| All times are GMT -8. The time now is 05:48 AM. |
