RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   parkzone P51 Micro problem (https://www.rcuniverse.com/forum/beginners-85/9288247-parkzone-p51-micro-problem.html)
Carevin 11-28-2009 10:53 PM
So I ended up get the RTF p51 micro from parkzone today.Read through the manual so I'd know exactly what was going on and what needed to be done. Charged the battery and went to start testing the flaps etc. I turned on the transmitter first then the plane. I get a solid red light on the plane so I know its sync'd to the parkzone transmitter. However while the rudder, ailerons, prop all work correctly. The plane is making noises that can only be desribed as morse code. I thought at first a servo was making it by jittering or something back and fourth 1 click. But by moving all the servos none made it stop the the sound. It really sounds like morse code.. Is this interferance? I thought 2.4 which even though its a really cheap transmitter should be "immune" to this. I do have a 2.4ghz wireless router for dsl in the house. Whats the deal?
jetmech05 11-29-2009 07:29 AM
RE: parkzone P51 Micro problem
2.4 is not immune to interference.....any freq can be interfered with.....FM is better than AM (remember the AM radios in cars going under power lines?) 2.4 is better than FM.....take your airplane outside away from your router and see if the morse code stops
Carevin 11-29-2009 10:38 AM
I was able to find one article where a guy posted review about how this seemed to be normal for it.
crash whiplash 11-30-2009 04:28 PM
I have the same thing going on with my P-51 setup, good to hear Im not the only one!
