Engine suggestions
Hi guys!
I am purchasing a Senior Telemaster (94") ARF. I intend to test a variety of electronics and imagery systems on it. The system could weigh upto 7 lbs. I am thinking of using OS 1.20 AX or the Zeonah G 26. Kindly suggest the better one. Thanks<br type="_moz" /> |
RE: Engine suggestions
For a video/photagraphy platform vibration needs to be minimized. It makes the video hard to watch and still photagraphy blurry. So an electric power system would be best. However, I cant stand the expense involved in electric and can justify batteries for a plane that size. So I would go with the Zenoah G-26 and work very hard at mounting the engine with shock absorbsion in mind (Rubber isolation mounts) to reduce vibrations through the airframe.
Hey!
Thanks a lot.. I did consider the electric system. However, the problem was the weight of the entire system. The system that I would be adding as the payload would be atleast 7 lbs.. and whatever electric configurations I could come up with were a bit on the heavy side. The flight time that I am targeting is around 30 mins. I felt that the AXi 5330/F3A is best suited for the purpose. However, the batteries proved to be a bit too heavy. Can you suggest an alternative arrangement? Also, would G20 be powerful enough for this system? <br type="_moz" /> |
The Telemaster has a huge wing. So long as your runway is smooth the G20 should be able to get that plane up to flying speed in a reasonable distance even with your 7 lb payload.
The Zen. G-26 will be ideal for you....it will sip gas and in its stock mag. form, be easy to start and no ign. batt. to have to charge. I wouldn't look any further for a powerplant!! You will not need any shock absorbing mounts either, balance your prop good and the huge airframe will soak up any further vibration. My G-26 is extremely smooth!!!
If vibration is an issue, wouldn't a 4-stroke or an opposed twin be a better choice if electric is off the table?
I don't think a single-piston four stroke runs any smoother than a single-piston two stroke. Why would it? Multi-cylinders are a different story.
I'm a gas or glow advocate usually, but the G-26 needs a bit of vibration so the diaphram pump will work. I believe it has even been recommended NOT to put a dampening motor mount on for that reason. (I can't remember where I read that - Bennett Built's website, perhaps but that might have had to do with a smoke pump installation). For a video platform I might be tempted to go with an electric motor, though I have avoided that route so far. The alternative would be to go gas and put dampers on the camera mount. Now THAT sounds like the ideal solution. |
ORIGINAL: Charlie P. I don't think a single-piston four stroke runs any smoother than a single-piston two stroke. Why would it? I agree that dampening the camera mount is the best way to go. |
| All times are GMT -8. The time now is 04:42 AM. |
