RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   hot wire cutting stuff (https://www.rcuniverse.com/forum/beginners-85/9463631-hot-wire-cutting-stuff.html)
Popriv 01-31-2010 09:28 AM
1 Attachment(s)
I'm sure its all been done before but here are some " block plane " cutters I made to cut in a spare on the foam wings I cut last weekend..
1st attempt was a square spare so I made a cutter of the appropriate U shape.
This made a very nice cut into the pink wing.
2nd attempt was to create a cutter to embed a rod into the wing and leave only one cutline showing.
I think this is what I will use on the final wing..
Screws on the end of the " plane " apply pressure to the wire so it doesnt move. Depth of cut can be adjusted here.
steve
The Ghost 01-31-2010 04:05 PM
RE: hot wire cutting stuff
Steve, thay are a great little idea. I have user the old trigger soldering gun with coper wire in the head, or a dremel with the router head.
Cheers
