4 Stroke Crankcase Vent
I have a Saito 150 that has the crankcase vent exiting under the cowl...i think i read in RCU that it is possible to route the crankcase vent tube and strap it to the muffler..... if i were to strap it with a plastic tie, would it hold up to the heat of the muffler?
RE: 4 Stroke Crankcase Vent
I would have more doubt about the plastic tie wrap around the muffler than the silicon rubber fuel tubing. It is after all the same stuff we use as header couplers for tuned pipes.
But I have a hard time visulizing the need to tie wrap the case drain to the muffler in the first place. John |
why not route it back into the tank?
1 Attachment(s)
i know it sounds like a weird idea, but the crank case vent is creating a mess to the belly of my plane when i come to cleaning...lots of debris to clean
you gave me an idea ... i think ill bend a piece of copper tubing and make a ring out of silicone fuel line |
ORIGINAL: aerofly0610 why not route it back into the tank? id be scared that it would put more oil into my tank or mess with the tuning |
The vent line in your photo is way to long.
It should only be about 4" so it can vent. It needs to breath in as well as out. The way you have it it will fill up with that oily crud and move back and forth in the tube and never make it out. Also it needs to vent to air, never run it back to the tank. [link]http://saito-engines.info/new_engine_prep__.html[/link] Tw |
I route my vent line back to the intake of the carb. All that is vented back is unburned oil, which is reused and blown out the muffler.
To me, it seems to improve milage on fuel and more lubrication. |
Zip tie is fine. All my Saito vents are zip tied to the muffler the same way. No problems yet. The muffler gets hot but it doesn't seem hot enough to melt my zip ties. I am usung a heavy duty zip tie not one of those dinky ones.
i trimmed the vent line down to 5 inches and strapped it to muffler.....if it doesnt work out ill keep you all posted
ORIGINAL: FLAPHappy I route my vent line back to the intake of the carb. All that is vented back is unburned oil, which is reused and blown out the muffler. To me, it seems to improve milage on fuel and more lubrication. so you use a T fitting and run the vent line back into the same line that dilivers fuel to the engine? |
I have for many years tapped the intake pipe on both Saito and my OS ENGINES for a 6-32 nipple. then route the crankcase vent into the nipple. gets rid of the mess and does not have any ill effects on the motor operation. Bruce |
No I do not use a T fitting. I take a piece of fuel line, cut it and cut a piece of tubing to fit into the vent line. Then I route that back to the carb inlet with a little bending etc, but just above the intake. It works great,, I strap that line to the motor mount with a couple of zip ties. I get a lot more fuel milage with a tank, about 3-4 minutes, and all the oil expelled is consumed back to the engine for lubrication. It works. If you just vent it out with a fuel line, it's wasted oil that can be used. The engines run perfect that I have done this on many engines, no needle valve mods or adjustments at all, except for frigid temps. I have not used a temp gauge on the head, but if they purrr, I don't need to. You know if it overheats.
ORIGINAL: Wonder The vent line in your photo is way to long. It should only be about 4" so it can vent. It needs to breath in as well as out. The way you have it it will fill up with that oily crud and move back and forth in the tube and never make it out. Also it needs to vent to air, never run it back to the tank. [link]http://saito-engines.info/new_engine_prep__.html[/link] Tw |
This whole thing of reusing the oil from the crankcase vent makes no sense to me. Any oil that has already been through the engine and the cumbustion process is going to contain microscopic metal particles and other contaminents. Especially on a 4 stroke since it goes directly into the combustion chamber before lubing the bottom end. Once it is in that vent tube I don't want it anywhere near the inside of my engine.-BW
I normally put a hole in the bottom of the cowl, or bottom of the fuselage, stick a rubber RATSHACK grommet in the hole to cushion the tubing and route the vent tube out this way.
You can easily put the tubing in via the grommet, and it holds the tubing in place during flights. If you need to remove the tank, cowl, etc. the tubing slides right out. No mess nor fuss. |
ORIGINAL: Bonified Wingnut This whole thing of reusing the oil from the crankcase vent makes no sense to me. Any oil that has already been through the engine and the cumbustion process is going to contain microscopic metal particles and other contaminents. Especially on a 4 stroke since it goes directly into the combustion chamber before lubing the bottom end. Once it is in that vent tube I don't want it anywhere near the inside of my engine.-BW |
ORIGINAL: Bonified Wingnut This whole thing of reusing the oil from the crankcase vent makes no sense to me. Any oil that has already been through the engine and the cumbustion process is going to contain microscopic metal particles and other contaminents. Especially on a 4 stroke since it goes directly into the combustion chamber before lubing the bottom end. Once it is in that vent tube I don't want it anywhere near the inside of my engine.-BW The opinion of metal being particles beinging mixed into the fuel again? I don't know about that, all I see is unburnt oil out of the vent. No metal particles at all. Everybody can choose whatever they feel is right for them. The engines run perfect, sooo. Do what ya want to do. |
ORIGINAL: FLAPHappy ORIGINAL: Bonified Wingnut This whole thing of reusing the oil from the crankcase vent makes no sense to me. Any oil that has already been through the engine and the cumbustion process is going to contain microscopic metal particles and other contaminents. Especially on a 4 stroke since it goes directly into the combustion chamber before lubing the bottom end. Once it is in that vent tube I don't want it anywhere near the inside of my engine.-BW The opinion of metal being particles beinging mixed into the fuel again? I don't know about that, all I see is unburnt oil out of the vent. No metal particles at all. Everybody can choose whatever they feel is right for them. The engines run perfect, sooo. Do what ya want to do. |
ORIGINAL: Wonder The vent line in your photo is way to long. It should only be about 4'' so it can vent. It needs to breath in as well as out. The way you have it it will fill up with that oily crud and move back and forth in the tube and never make it out. Also it needs to vent to air, never run it back to the tank. [link]http://saito-engines.info/new_engine_prep__.html[/link] Tw |
I think I read somwhere here an idea of adding a small 1-2 oz tank and letting the vent line run into it. I haven't tried it but it sounds like a winner to me.-BW
ORIGINAL: Gray Beard Even so, I still question having old nasty crap flowing back through my engines?? |
ORIGINAL: aerofly0610 ORIGINAL: Gray Beard Even so, I still question having old nasty crap flowing back through my engines?? |
I tend to agree with greybeard, why cycle any impurities and wear particles back through the engine again to create more wear and tear. Any microscopic particles from piston,rod,cylinder etc. will just create and/or accelerate further wear. I know most of the newer designs on 4 strokes do that but; if I were selling engines, I'd like to see the old ones wear out faster too. Now most of that goop coming back out through that breather tube is oil and byproducts from the burning of the fuel, no real value or increase in mileage as the oil does not burn, only the alcohol/methanol is burned unless you are running lean and then; you will have more serious problems as the temperature will be excessive.
I would just drill and tap and put in another nipple to the muffler, and have the breather go out that way. I guess that's the easiest and neat way to do it from my research.
Pete |
ORIGINAL: Oberst I would just drill and tap and put in another nipple to the muffler, and have the breather go out that way. I guess that's the easiest and neat way to do it from my research. Pete |
| All times are GMT -8. The time now is 07:44 PM. |
