Solar tex
what is solar tex covering and where can i but it i have a plane i am wanting to scale and paint looks like this covering is good for that buy what i have saw in a post
RE: Solar tex
I buy mine from Balsa USA: https://www.balsausa.com/store/categ...?id_category=8
You will enjoy using it, great to work with. Bill D. |
RE: Solar tex
ORIGINAL: bbrown2828 what is solar tex covering |
RE: Solar tex
I have used SolarTex on numerous occasions. It is a VERY GOOD covering that goes on at LOWER HEAT
than most filme coverings. It does wingtips and curves like a dream. The colored coverings (definitely) are fuel proof. One suggestion I will offer, especially with glow fuel engines - after you have applied all your decals and trim paint, give the covering a coat of clear (the clear coat also seals the decals and really minimizes their lifting). While the covering is fuel proof, the weave of the fabric tends to hold the dirt and grime. You will find cleanup much easier with the clear coat (easier than using a fingernail brush to get the dirt off). |
RE: Solar tex
Users of Solar Tex,
Monocote and Ultracote have a tendency to lift at the edges. Occasional resealing with the iron is not a problem. Does Solar Tex have this problem? Does painting make the problem go away? Thanks, KW_Counter |
RE: Solar tex
ORIGINAL: KW_Counter Users of Solar Tex, Monocote and Ultracote have a tendency to lift at the edges. Does Solar Tex have this problem? Does painting make the problem go away? Painting or clearcoating will make the model much easier to clean and keep it nice and tidy. 'Tex seems to be a filth-magnet if it isn't smoothed over. |
RE: Solar tex
Psuguru,
Thanks for the info. What does your handle mean? Thanks, KW_Counter |
RE: Solar tex
I've been thinking of use 'Tex. What are you using as paint and what fuel proofs that paint?
RE: Solar tex
I usually use a latex paint then clear coat using a CLEAR AUTOMOTIVE/ENGINE ACRYLIC ENAMEL.
Since Ultracote clear has disappeared, that leaves Lustercrap. Rather than go through the aggravation of Lustercrap, I have found that many acrylic clear enamels range from fuel resistant to fuel proof. Be advised that you WILL NOT get a film type shine with latex - all the shine is in the clearcoat. If you absolutely must have fuel proof, use Nelson's clear with the crosslinker (requires spraying equipment. Nelson's is very good, but not cheap) |
| All times are GMT -8. The time now is 12:56 PM. |
