need Propeller help mine is broken
hi everyone.
my airplane is hangar 9 alpha 40 dms2 RTF. It came with the <span class="ContentText">Propeller when i bought it. Today i broke it in the field and need replacment for it. in kuwait i could not find any replacment for it, what i mean is the same propeller as the one i broke. In matter of facts we dont have any three blades </span><span class="ContentText">Propellers in the market. so my quistion is what can i replace the </span><span class="ContentText">10.5x4 three blade propeller with. any suggestions will help thanx in advance </span> |
RE: need Propeller help mine is broken
I understand shipping chargs may be very high, but cant you order from any internet store?
ORIGINAL: stevenmax50 I understand shipping chargs may be very high, but cant you order from any internet store? thanks m8 |
you could use a 2 blade, just add an inch and the pitch could be either the same or a bit bigger.
That is a 40-46 engine if I recall.
Any 2 blade of 10-6, 11-4/5, will do the job for flying. You will have to use just a nut, spinner-nut or another spinner since I'm thinking your spinner is cut for a 3 blade. Good luck. |
After I soloed on my Alpha 40 I switched to APC 11x6 props. You will need to get a new spinner - I highly recommend using spinner nuts. I have switched to them exclusively, and I'll never buy another plastic spinner.
http://www3.towerhobbies.com/cgi-bin...?&I=LXE158&P=0 Grab a few different size props and experiment. The spinner nut makes it really easy to change props and you can still use a standard starter cone. Good luck |
hanx guys for he help i will buy apc 11X6 porp with a spinner nut tomorrow and give it a go. i really thank you all for your time and will let you know how it went tomorrow
thanx guys |
| All times are GMT -8. The time now is 04:43 PM. |
