When To Wing It
If I go over my plane I find things to adjust . Than later I think of something else. and so on. After some time, it can get very expensive and time consuming.
Than at the field you think why did I try so hard? Or why did spend so much. and so on. Am I the only One that does this? |
RE: When To Wing It
If you enjoy what you do, who cares?
If you are not having fun, then you need to rethink your approach to the hobby-sport.[sm=71_71.gif] When I started, I was a little like that, but later, I learned to relax and enjoy mine and others' models. Regards! |
RE: When To Wing It
ORIGINAL: ES CONTROL If I go over my plane I find things to adjust . Than later I think of something else. and so on. After some time, it can get very expensive and time consuming. Than at the field you think why did I try so hard? Or why did spend so much. and so on. Am I the only One that does this? I don't consider that "trying so hard" and when it comes down to the expense.........I don't count! |
RE: When To Wing It
I would think Winging It wouldn't be a good idea, You should always check your batteries, flight surfaces ,hinge points,control horns, prop , engine mounts, etc before you put a plane up. I have found broken and loose hinges, wallowed out control horns , batteries that have had a cell go bad , all kinds of little things , that could turn into big things once in the air. I would think a preflight inspection is one of the most important things one should do.
RE: When To Wing It
ORIGINAL: ES CONTROL If I go over my plane I find things to adjust . Than later I think of something else. and so on. After some time, it can get very expensive and time consuming. Than at the field you think why did I try so hard? Or why did spend so much. and so on. Am I the only One that does this? |
RE: When To Wing It
There are things that are important, and things that are not.
Then there are things that are important to SOME people whiel others don't care. For instance, having good batteries that are fully charged is important. Having a small tear in your covering can be important on some models, but with other models, you can get away with a few flights for that day, but fix it when you get home. To some people, having a plane that is totally clean, grease-free and shiny is important. I usually give my planes a good cleaning in the spring, then just a quick wipe-down after flying (Can't beat OS 4-strokes for keeping your plane slime-free!). Let's face it, we're all different. Some people will spend hours getting a tail wheel perfectly aligned. As for me? I'll just hold a little rudder while I taxi out. Diffrent strokes for different folks! |
| All times are GMT -8. The time now is 12:16 AM. |
