RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Battery pack safe to use? (https://www.rcuniverse.com/forum/beginners-85/9664268-battery-pack-safe-use.html)
shd3920 04-15-2010 09:49 PM
1 Attachment(s)
I have two lipo 800mah 2S 20C battery packs that the wires were cut and spliced with a Deans female connection. The battery pack wires are probably 16 gauge and the Deans connectors are 14 gauge wires. Is that difference acceptable and are the battery packs safe to use?
Redback 04-15-2010 09:55 PM
RE: Battery pack safe to use?
The wire gauge should not be a problem.
The insulation, especially on the black wire looks a little suspect in the photo. Short circuits are bad news at any time, and especially so in lipos!
Terry
RCKen 04-15-2010 10:19 PM
It depends on what you are going to have connected to it. If it's going to be a high amperage motor then the smaller wire may cause a problem. However, it's going to power a receiver then it should be ok. Either way, I agree with Redback and the insulation needs to be fixed.  A proper solder job on the wires with good heat shrink to insulate the wires.
Ken</p>
shd3920 04-15-2010 10:44 PM
Going to be used on a Park 400 Outrunner motor with 20 amp ESC
The black wire is insulated with shrink wrap and then was covered with electrical tape because a tiny spot was not covered by the shrink wrap
Bonified Wingnut 04-15-2010 10:52 PM
More than enough...-BW
RCKen 04-15-2010 10:55 PM
Agreed.
Ken
MinnFlyer 04-16-2010 07:19 AM
Yea, Ken, what you forgot is that with wire gauges, the smaller the number, the heavier the wire. So the soldered-on leads are actually BIGGER than the originals.
No problem - but I would re-wrap that splice.
CGRetired 04-16-2010 08:56 AM
Yeah, I gotta agree. Electrical tape has a bad habit of coming un-done. I'd cut it and re-splice it with the correct amount of shrink tubing.
CGr.
Rodney 04-16-2010 08:58 AM
While your splice (wrapped with tape) may not look so good, IMHO it is perfectly safe and should cause no ill effects on performance. Yes, the larger gage wire you used is very adequate.
Mr67Stang 04-16-2010 09:08 AM
As said, going from a smaller wire at the pack to an equal or larger size at the plug will not be a problem. Going the other way could be. Just ensure those spliced connections are good and solid as well as well insulated.
