RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   hello alll (https://www.rcuniverse.com/forum/beginners-85/9671843-hello-alll.html)
avgrech 04-19-2010 06:01 AM
hello alll
hello everyone i am Andrew fromMaltaand i am abeginnerRCpilot and i am a member in a********associationand i have an electricCessnawhich i love but i just got a 20 cc engine and i`d like to fit it on an aircraft. can anyone suggest abeginnerairplane to fit this engine in please ?<br type="_moz" />
Korps 04-19-2010 06:09 AM
RE: hello alll
20cc engine or .20 engine? Welcome to the hobby and forums. However I'm going to refer you to another thread where RCKen has put a list together of proven beginner airplanes. I'm sure someone else will cut into the thread and give your further advice. From my side I would recommend getting a .46 or .60 size trainer. Also, do you have any experience with flying and if so to what degree?
Korps 04-19-2010 06:11 AM
RE: hello alll
Here is the link http://www.rcuniverse.com/forum/m_4537845/tm.htm
Mr67Stang 04-19-2010 06:40 AM
RE: hello alll
If it is a 20cc gasoline (petrol) engine then a telemaster is about the only beginner freindly plane to put that on.
avgrech 04-19-2010 03:06 PM
RE: hello alll
hello again 10x for your advice and yes it is a 20 cc engine or at least that`s what it`s got written (i got it as a gift). i havejuststarted with myCessnaand i am going to start to do landings on my own soon i can fly good with sometroubleon take off as i`m still learning
Korps 04-20-2010 12:23 AM
RE: hello alll
If I may ask what Cessna are you flying? You said it's electric, but which one.
Sandmann_AU 04-20-2010 01:29 AM
RE: hello alll
ORIGINAL: Mr67Stang
I dunno... a 20cc gasser should work ok on a Seagull Spacewalker 120 - they're pretty non-threatening too. :D
avgrech 04-20-2010 03:33 AM
RE: hello alll
theCessnais a small one with a bit less than 1meterin wing span i`m going to do some modifications, am going to change the motor and battery , i got it a 11.1 V 2200 mha vattery and a 1400kv motor if i remember correctly and today i have justrevivedareviverfor myscratchbuild.
