Prop shaft question
Hi guys,
Iburned 15 tanks on my OS 46AX and noticed that the prop shaft has play in it..Not side to side but in and out. Enough play to where if I push it in and turn it by hand, it feels rough likeit's rubbing against somethingBut when in the normal seatedor pulled position it turns smoothe. Does that make sense? Thanks http://www.rcuniverse.com/forum/js/f...sn/biggrin.gif |
RE: Prop shaft question
Have you had it apart before? There's a washer that goes inside there that prevents that rubbing. Maybe yours got left out?
No I haven't hadit apartit's still a new engine. If I do will I void anything with OS?
Thanks |
There is a washer behind the thrust washer behind the prop - if it came off when changing a prop the washer/spacer could fall off. Another thing could be the crankshaft rubbing the back plate due to bump starting (spinning the starter then bumping the spinner).
Don't worry about it. It's normal
Thanks guys. If it's normal that's great! delman, I have the prop,thrustwasherandother washeroff the engine to where it's only the shaft sticking out. I never used an electric starter on itjust a chicken stick. But if it's normal cool I won't worry about it unless I start hearing knocking or something. Just seems not normal..lol http://www.rcuniverse.com/forum/js/f...sn/biggrin.gif</p> |
ORIGINAL: drube Thanks guys. If it's normal that's great! delman, I have the prop,thrust washer and other washer off the engine to where it's only the shaft sticking out. I never used an electric starter on it just a chicken stick. But if it's normal cool I won't worry about it unless I start hearing knocking or something. Just seems not normal..lol [img][/img]</p> remember then the prop is spinning it will pull the shaft forward so their wont be play |
ORIGINAL: drube I have the prop,thrustwasherandother washeroff the engine to where it's only the shaft sticking out.</p> -rep |
Hi!
All ball bearing engines should have slight axial play (0,1-0,3mm). |
1 Attachment(s)
ORIGINAL: jaka Hi! All ball bearing engines should have slight axial play (0,1-0,3mm). If the prop was loosened, being that the ax doesn't use a collet on the drive hub, (just has a flatside on the crank), that would allow the crank to slide back & rub against the back plate. That's why I was trying to find out if the original poster had the prop off when he noticed excessive play & rubbing. If so, that would be normal. If prop was tight & crank was still rubbing on backplate, that would indicate perhaps the thrust washer is missing? -rep Drube- just make sure you have #10 (in the pic) in your engine.http://www.rcuniverse.com/forum/js/f...ular_smile.gif |
That makes sense, I noticed it after the prop was offsoI'll check it again when the prop is back on and let you know. Thanks for the diagram! http://www.rcuniverse.com/forum/js/f...sn/biggrin.gif |
If number 9 has never been off, you shouldn't need to worry about number 10.
ORIGINAL: drube I have the prop,thrustwasherandother washeroff the engine to where it's only the shaft sticking out.</p> He clearly says it's been off. Anyway, the drive hub just slides off. Sure wouldn't hurt to check. |
ORIGINAL: drube Thanks, That makes sense, I noticed it after the prop was offsoI'll check it again when the prop is back on and let you know. Thanks for the diagram! http://www.rcuniverse.com/forum/js/f...sn/biggrin.gif -rep |
If it's never been off, then leave it alone. Taking it apart may lead to the OP losing the "#10" which, if I recall, is very thin small part.
Experienced people said it's normal. Leave it at that and fly the thing. If it ain't broke, don't fix it. CGr. |
ORIGINAL: drube No I haven't had it apart it's still a new engine. If I do will I void anything with OS? Thanks HTH JIM |
| All times are GMT -8. The time now is 04:19 AM. |
