RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   NITRO ENGINE SIZE (https://www.rcuniverse.com/forum/beginners-85/9709809-nitro-engine-size.html)
DIVERHERB 05-04-2010 11:23 AM
NITRO ENGINE SIZE
Being new to RC I have a question on engine size. I have a plane that I built from balsa that looks similar to a Ugly stick but is a low wing model. noise wheel with a 53 inch wing span.
I think when all is done should weigh in at 3 pounds or less. What would you suggest for an 2 stroke engine size? I am not expecting screaming performance from it just a fun plane to fly and learn some mild manuevers on. The is a 4 channel if that makes any difference. Thanks for the help.
Herb
Mr67Stang 05-04-2010 11:33 AM
RE: NITRO ENGINE SIZE
By wing span I would say a bearinged .40 to .46 leaning towards the .40 by the weight you posted. However the engine and electronics will likely bring you up to 4-5 lbs when all is said and done so, I am back to the .46:D
RCKen 05-04-2010 11:37 AM
I agree with Stang. a good .46 should take care of getting that bird in the air.
Ken
JohnBuckner 05-04-2010 12:32 PM
By size and weight If it is a typical sport plane my ideal recomendation would be a quality .25 to .35 such as the OS AX's.
Also this likely a poor choice in first airplanes if that is what it is especially if you overpower.
John
DIVERHERB 05-04-2010 02:56 PM
I am figureing that the all up weight with engine and electronics to be 3 pounds or less. It will be my first nitro plane as I have been fooling around with electric park flyers. Thanks for any input.
Herb
JohnBuckner 05-04-2010 03:13 PM
.25 to .35
Mr67Stang 05-04-2010 03:27 PM
Can you post a picture of the plane? We might be able to identify it and tell you what the manufacturer says belongs in there. But at 3 Lbs or less with engine, servos, battery, etc. then yes, a .25-.35 ought to do it.
jimmyjames213 05-04-2010 03:29 PM
i would see if you can get a used .40-.46 bushing engine such as a os .40 la, os .46 la, mangum .40 gp, tt .42, or os .40fp to name a few
if not a .25-35 would be plenty
DIVERHERB 05-04-2010 08:40 PM
What is meant by a "bushing" engine? I have a an older O.S. max 45f and an O.S. 25 and a 20 all 2 strokes
I also have a Como S 40.
RCKen 05-04-2010 08:49 PM
It means that the engine does not have ball bearings to support the crankshaft. There are simply metal bushings (basically a piece of metal with a hole in it) that support the crankshaft. Many of the bushings engines from OS and other manufacturers are still very good engines and serve many good roles for flying. I have an old OS 40 on my first trainer that has bushings in it, and the plane is 14 years old. and still flying.
Ken
flyinrog 05-04-2010 09:41 PM
Well, if your new enough, then we dont want you spending money on a high powered bearing engine, your gonna drive into the dirt,,,,so lets stay with the bushed OS LA .25-.40 engines, they run like a timex and if you cave in a front end, you wont be out too much money....Rog
proptop 05-04-2010 10:30 PM
ORIGINAL: DIVERHERB
What is meant by a ''bushing'' engine? I have a an older O.S. max 45f and an O.S. 25 and a 20 all 2 strokes
Out of your collection, I would go with either the O.S. .25 or the Como .40 (providing they're still in good running condition? )
DIVERHERB 05-05-2010 06:25 PM
Thanks for the input. I have bench started all of the 2 strokes and they all run great, None have ever been run into the ground. I still have 3 4 strokes I have yet to try to start but plan to this weekend. Its been a long time and I dont really know why I stopped this hobby. Maybe raising a family who knows. But I am just starting out again and I am really having a blast. Thanks again. I will try to post picture of my low wing Ugly stick? as soon as Iget a chance.
Herb
