glider
Is a unpowered sailplane about 50 inch wingspan a easy to fly model.
In terms of thermal soaring. all help is apprecaited JM |
RE: glider
easy to fly yes and very forgiving I was self taught using un powered and powered gliders its a great way to learn how to fly , however thermal soaring or chasing is a little more complicated and will take some practice
Good luck ! |
RE: glider
thanks
JM<br type="_moz"/> |
RE: glider
First question is do you already know how to fly?
The size of glider you're looking at is a little on the small side for thermaling, but may be able to thermal (it would help to know which glider you are talking about). From my experience, a 2M glider is generally one of the easiest to learn with. They don't require a heavy duty hi-start, and with their light weight and wing area will thermal quite well with minimal lift. Hogflyer |
| All times are GMT -8. The time now is 01:27 AM. |
