RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Hobbyzone Mini Super Cub Problem - Please help (https://www.rcuniverse.com/forum/beginners-85/9742060-hobbyzone-mini-super-cub-problem-please-help.html)
stjimmyl 05-18-2010 10:17 AM
Hi Guys,
Ive recently started to love RC planes and after a few flights with my Hobbyzone Mini Super Cub, I crashed (oops) and after a few bits of tape to repair a very small piece of damage to the top of the rudder, it wont take off. The nose did take a bash in the accident and the rotor looked wonky - I have straightened this and it still wont lift off.
Is there an angle the prop and prop shaft should point - at the moment it points slightly up so the wind it produces goes over the wings.
Any advice gratefully received to get me back in the air....
Thanks! :)
James<br type="_moz" />
Mr67Stang 05-18-2010 10:53 AM
RE: Hobbyzone Mini Super Cub Problem - Please help
1 Attachment(s)
On those planes the prop shaft needs to be pointing DOWN for "down thrust angle". My illustration is grossly exagerated... And no, I'm not 3 yrs old:D
stjimmyl 05-18-2010 11:12 AM
Hi Stang - my prop is at this angle - however, it still wont take off - any ideas?
Thanks for the fast response!
Cheers!
Mr67Stang 05-18-2010 11:14 AM
Do you have less power than you did before the crash? If you bent the prop shaft it may be wearing funny and causing extra load/resistance inside the motor.
stjimmyl 05-18-2010 11:21 AM
Now youve said that - I think there is a bit less power - is there a fix for this, or am I buying a new plane here?
Is there a way to check it's bent - can I remove it?
Thanks again for all your help!!
Cheers,<br type="_moz" />
Mr67Stang 05-18-2010 11:30 AM
Take the cowl off. With the plane turned off and battery removed, turn the prop by hand while looking at the shaft comming out of the motor and the center of the prop. Look for a wobble. If it apears straight. Install the battery and carefully hold the plane and observe the prop and prop shaft for a wobble. If it wobbles, it is bent.
Mr67Stang 05-18-2010 11:33 AM
Click [link=http://secure.hobbyzone.com/search/HBZ4804.html]ME[/link] for a new prop shaft.
Or [link=http://secure.hobbyzone.com/search/HBZ4829.html]ME[/link] for a new shaft and gear box.
goirish 05-18-2010 11:38 AM
ORIGINAL: Mr67Stang
On those planes the prop shaft needs to be pointing DOWN for ''down thrust angle''. My illustration is grossly exagerated... And no, I'm not 3 yrs old:D
I would have never guess a 3yr old, maybe a 1 year old.:D:D:D
Mr67Stang 05-18-2010 11:42 AM
ORIGINAL: goirish
ORIGINAL: Mr67Stang
Alright goirish, pop out your MS Paint fusalage profile in 45 seconds or less:D
