HELP!!!
Hello
Can enyone Help me ! Have just purchased a Boomerang 40 and am in the process of putting it together ( first time ever) andam following the instructions that came with the plane, have so far managed to get quite far with building this plane but knowI`m STUCK! It tells me to install the SWITCH. I have no idea what there on about! I`m using a Spectrum DX7 radio and installing the servos that came with that radio. I have found a switch that hasON andOff written on it, is this the switch I`m suppose to be using? Certainly does NOT fit in the hole in the bottom of the fuselage, the picture in the instructions show a switch in the middle of the fuselage which has a wire running from itthrough the side of the plane. Have no idea what this is suppose to do?http://www.rcuniverse.com/forum/js/f...ngry_smile.gif Can anyone HELP!!!!!! dutchy50 |
RE: HELP!!!
that will be the switch they are talking about it goes between the battery and the receiver to isolate the power supply to receiver,there is also or should have another wire on the switch which is the charge lead wire which plugs in to your charger (always turn plane Rx of first before transmitter Tx )
| All times are GMT -8. The time now is 03:38 AM. |
