RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Servo Torque Suggestion (https://www.rcuniverse.com/forum/beginners-85/9797688-servo-torque-suggestion.html)
nrad2000 06-12-2010 03:28 AM
I'm thinking of building an ARF Aero-Works Edge 540T 60". Any suggestions on Servo's?
What about for a 60 - 90 Yak 54 from Aero-Works? Any suggestions on Servo's?
I have a bunch of DS821's - will those work for both airplanes?
Lnewqban 06-12-2010 07:01 AM
RE: Servo Torque Suggestion
http://www.rcuniverse.com/forum/m_97...tm.htm#9775406
j.duncker 06-12-2010 09:23 AM
If you want to knife edge you will need more torque on the rudder servo. Other surfaces should manage OK
ByLoudDesign 06-12-2010 09:41 AM
There is a formula and table that helps you get in the ball park!!
Lnewqban 06-12-2010 09:51 AM
Here you have an on-line calculator:
http://www.geistware.com/rcmodeling/calculators.htm
ByLoudDesign 06-12-2010 01:48 PM
THAT is a cool program!!! It would be better if it were in inches, but I use boyh Metric and English so not a problem. THANKS!!!
