T 28 Trojan control problem
I have a T 28 Trojan and on the forth flight it went into a dive and I had no control over the aircraft. Both times I was able to get control back before it hit the ground, but it was like I had lost contact with the plane. I am using a Spectrum DX5e transmitter and AR500 receiver. I was also using the battery out of my Mustang BL, if that matters. Does anyone know why the plane would do this. I have been flying my Mustang for about two months and have never had this problem before.
RE: T 28 Trojan control problem
That sounds like a low voltage reboot. Either that or you have a bad servo or a bad component in your radio system. If you got 4 good flights then this started happening, I'd definitely suspect the battery. What are you using, and are you checking it with a loaded meter between flights?
lancer it's poor etiquette to post the same question in multiple places. This is at least three I've seen so far.;)
You've gotten pretty much the same answers in every post you put up. What you didn't believe us in the other ones?:D |
Yep I'd say low voltage as wel.....posted in 3 places??????
| All times are GMT -8. The time now is 07:45 PM. |
