upgrade to Brushless
I have a Cessna 747 plane.
I m planning to upgrade it to brushless motor. Do you know which motor, esc, prop, batteries should I get. please advice. thank you Here are the spec. of my plane: Flying Weight 440g Original Motor: 370A with gear box What does 370A means? Size? There are different 910KV...2800KV motors. Power? |
RE: upgrade to Brushless
A small foam Cessna model just under 1lb. in weight would fly well with any number of different brushless outrunner motors.
Look for something in a 28mm diameter, 30mm length size rated between 950kva and 1400kva. Match it with a 12 amp to 18 amp ESC and a 2S or 3S LiPo battery in the 500mAh to 800mAh size range. Try a few electric slow flyer props in the 8" to 10" diameter range to find the size you like best. Good luck and good shopping! |
| All times are GMT -8. The time now is 11:28 AM. |
