RE: What is the best LIGHTWEIGHT starter?
The PACaeromodel unit recommended several posts ago is an excellent unit. 21.6V (3 X 7.2V) battery slung right under the small starter. I have used it to start a G62!
ORIGINAL: VF84sluggo For the mechanically challenged (i.e., me): How do you convert the end of the drill to an airplane starter? I sure like the pistol-grip style with a battery base that also serves as a stand. Sorry the link I provided in post number 22 for the cheap drill as described in my post number 21 is to just use the battery and charger to be used with an ordinary starter The whole idea is to increase the voltage you are providing to a standard starter. As far as using a drill or screw gun for a starter goes because of the pistol grip which is the wrong ergonomics for use as a starter they can be very dangerous if one tries to use it with one hand. They can only be used safely with the operator using both hands and someone else holding and pushing aginst the starter man. At some point when flying say 40/60 sized airplanes someone will attempt to use one by himself and one handed with the other holding the fuselage and this is where it becomes very dangerous. Just try it, pick up a drill and hold a fuselage of an airplane with the other hand and try to line up the drills axis with the prop shaft axis and then pull the trigger. Its for this reason I strongly reccoment not useing any pistol grip device for an airplane starter. John |
Thanks! You guys are awesome!
I have the heavy duty sylvan, but think it may be fried, even though I took it apart and looked at the
motor brushes... Can't wait to see what happens when companies start making BRUSHLESS starters?? Price increase? Also, I may call up sylavan, and get the motor for the DYNATRON (50$) and stick it in the HD sylvan starter... Costs half what it would to buy it new... The grear reduction starters typically do not spin the prop fast enough to start the smaller engines.. can't remember the exact synario....but one guy couldn't get one going, then realized that the starter was TOO big and slower for big GAS engines...ect.. |
1 Attachment(s)
http://www.youtube.com/watch?v=0q0q5E2IMR4
THis is a good idea for you old farts.... Self made smart starter!!;):D Heck I will be a old fart soon too!... Better start making it now!![:-] I think HE pulled the plans for it because someone, was selling a version of it.... hosed him off apperently!!!! |
ORIGINAL: JohnBuckner ORIGINAL: VF84sluggo For the mechanically challenged (i.e., me): How do you convert the end of the drill to an airplane starter? I sure like the pistol-grip style with a battery base that also serves as a stand. Sorry the link I provided in post number 22 for the cheap drill as described in my post number 21 is to just use the battery and charger to be used with an ordinary starter The whole idea is to increase the voltage you are providing to a standard starter. As far as using a drill or screw gun for a starter goes because of the pistol grip which is the wrong ergonomics for use as a starter they can be very dangerous if one tries to use it with one hand. They can only be used safely with the operator using both hands and someone else holding and pushing aginst the starter man. At some point when flying say 40/60 sized airplanes someone will attempt to use one by himself and one handed with the other holding the fuselage and this is where it becomes very dangerous. Just try it, pick up a drill and hold a fuselage of an airplane with the other hand and try to line up the drills axis with the prop shaft axis and then pull the trigger. Its for this reason I strongly reccoment not useing any pistol grip device for an airplane starter. John I understand your post now. Thanks, and also thanks for the good safety info. Randy |
ORIGINAL: VF84sluggo ORIGINAL: dignlivn Have you thought about uping the voltage ? I use 4 cell lipo (30C 3200 mAh's) for my hobbico 180 starter. Works great and last all weekend and then some. Bob Do you have any pics of your starter you could post. I just picked up a plane that has a 26cc RCGF motor. I don't think my current starter (maxed out turning a Saito 100) will work. The Hobbico 180 looks big enough, but I'd like to get away from cords, too. I'll try and post some later today, Bob |
I have been using the Kavan starter (B&P sells it as linked in post #16) for years and love it. I don't have any problems with it starting glow engines up to 90 2 stroke and 120 4 stroke (largest I have). I am currently using it with a B&P battery pack at 14v.
hello......go to hobbypeople.net and search "magnum starter".......they are small, light and start my 180 4 strokes.......49 bucks.......they are similar in size to the kavan starter only cheaper......i have had mine for over 5 yrs.........i have arthritis in my hands and have difficulty using the standard size starters........you will like these....i use a wally world lawnmower battery at the field to power it.........pault
<span style="font-size: larger;"><u>M A G N U M S T A R T E R</u></span>
http://www.hobbypeople.net/gallery/237960.asp |
I got rid of my heavy starter and got the Magnum starter. Have been using it a year to start .90 2-cycle and 1.20 4-cycle engines. Works great, and is much smaller and lighter!
KAVAN, KAVAN, KAVAN!!! Yes, that is the best starter available for it's size and power. It will easily start any 1.20 on 12 volts and is small and easiy grasped by even the smallest hands. It cost a couple of bucks more than some but is well worth the extra price.
I understand your need for lightweight, but as has been mentioned already, the Kavan is the lightest weight I know of but needs higher voltage. The link below is for an adapter that allows the use of slide on 18v Makita battery packs. May not be as light as you wanted, but certainly has the power to turn almost anything. It also is surprizingly well balanced.
www.afineredgemfg.com Rick |
I have two finer edge adapters, on on a sullivan dynatron, and the other on a reduction belt starter.
I use one Makita lipo between both For weight, get a Kavan. Really. 1. lightweight 2. easy to hold even for small hands 3. great switch 4. Even with a lipo, still light weight that combo is hard to beat. I use a sullivan mostly, but the switch stinks. period. billrad |
Two guys at our field have this made by Align. It did start my Da 50 as a test. Portable,Small and powerful.
http://www.completeheli.com/Align-Su...plane-HFSSTQ02 |
Man for that price it should come with a human starter to do the grunt work LOL
Nice if ya can afford it , but us po folk have to use the tower stuff |
ORIGINAL: dmowery Man for that price it should come with a human starter to do the grunt work LOL Nice if ya can afford it , but us po folk have to use the tower stuff |
Was out at the flying field all day.
Tried my Sullivan Dynatron w/12v garden tractor battery a few times on a Saito 220 and it started it right up Also hooked up two emergency light 12v gel cells together in series for 24v and started the same Saito 220 using a Hobbico 90 starter. |
Have made lots of starters in the past, have learned a lot and find Outboard motor starters are great, cheap and plentiful, have 3 here ready to go. Send note if interested.
ORIGINAL: w8ye Also hooked up two emergency light 12v gel cells together in series for 24v and started the same Saito 220 using a Hobbico 90 starter. Also, is the Hobbico 90 motor durable enough to handle the extra volts? Right now I use it with banana plugs and the stock 12V battery that all came with the field box kit. I will say this: After using the 90 with a cord plugged into the field box, I can now see why guys at the field have all these duct-taped starter/battery contraptions that free them from being tethered to a battery in a field box. |
Based upon an idea someone posted here, one of our club members put together a nice adjustable starter system that does NOT require you to lift anything as you start a plane.
The electric starter is mounted on a post with a moveable height adjustment, and there is a trip switch on the post. The idea is that while holding the plane on the ground you push the spinner cone into the starter cone, causing the electric motor to start and turn. Since he only had to lug the battery out to the field and back, he ended up using a motorcycle battery. Once in place he had no need of moving the starter. |
Here is a link to a great lightweight cordless starter. They are expensive in my opinion, but I bought one used from a club member and I love it. Plenty of power and lightweight.
http://bpassociates.homestead.com/STARTERpacks.html Indy Park flyer |
ORIGINAL: Indy Park Flyer Here is a link to a great lightweight cordless starter. They are expensive in my opinion, but I bought one used from a club member and I love it. Plenty of power and lightweight. http://bpassociates.homestead.com/STARTERpacks.html Indy Park flyer The Magnum at $39.99 which is also available from Hobby people The Kavan at $54.90 which is also available from Hobby Lobby These are both excellent starters. I have experience using the Kavan. Eventually, after many years, the planetary gears will let go |
w8ye,
The prices you listed are for the starter only, without the battery pack. Unfortunately, when you add the battery pack, the price jumps significantly. Indy Park flyer |
| All times are GMT -8. The time now is 08:50 PM. |
