can you undo ca
i screwed up on the tailsection of a kyosho spacewalker... can i undo the ca on the hinges to undo what i have done and do it over correctly
RE: can you undo ca
The easiest and best way is to cut the old hinges then re-hinge with new ones next to the old hinge positions. Trying to remove and debond the existing hinges is difficult at best.
RE: can you undo ca
thnx for the help. i cut the hinges and it looks like crap but i think it will work
RE: can you undo ca
Ca debonder is acetone. several application will turn the Ca to rubber. But it will be a pain to get any acetone into the hinge slots. Small drilled holes and patience with an eye dropper????
RE: can you undo ca
ORIGINAL: RookieFlyerDoug thnx for the help. i cut the hinges and it looks like crap but i think it will work It shouldn't... just trim them all the way up to the control surface then make new slots..... if done correctly, you wouldn't even see the old hinges.... |
RE: can you undo ca
and what about taking the "bad" hinges off with a hobby knife and replace them with nylon hinges glued with epoxy? it worked for me when I did the same ugly job installing hinges for the first time.
RE: can you undo ca
ORIGINAL: chocorrol and what about taking the ''bad'' hinges off with a hobby knife and replace them with nylon hinges glued with epoxy? it worked for me when I did the same ugly job installing hinges for the first time. |
| All times are GMT -8. The time now is 05:42 AM. |
