Brushed/Brushless motors, speed controls, gear drives Discuss all aspects of brushless motors, brushed motors, speed controls (ESC's), gear drives and propellers in this forum.
Plane should be setup with 6s want to use 5S
Old 09-14-2010, 11:35 AM
Default Plane should be setup with 6s want to use 5S
Hi
ok I can buy new batteries but I want to use the 5s that I have on this bird!
I have an engine <font color="#00265e">http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=7070</font>but I got a advice that to be abel to fly the plane (Wind S 50) through the P011 I should use 6S.
So....as I working as a winder (electrical engines and generators) I should have no practical problems to rewind the enginge to get the KV that I need , I was told I should have around 450-500, the engine has now 380.
I have posted the same question here before but didnt get any full answer...can I rewind it with maybe 1 turn less in the coils??? have search but the engines I found is a bit smaller than this .
so the question is ...will you get higher kv by less turns and vica verca????
I know that I have to adjust the wire thickness when I change the number off turns.</p>
Old 09-14-2010, 04:13 PM
Default RE: Plane should be setup with 6s want to use 5S
Fewer turns = higher Kv
Old 09-14-2010, 08:04 PM
My Feedback: (90)
TLH101's Avatar
Why even change the motor at all? Just us a higher pitch prop.
Old 09-16-2010, 08:30 AM
can get 2 " more pitch than I planned but it mybe not enough!
well my plan is try the plane with the things I have .....if it not enough I rewind the engine ,should be a quick smal job .
It has 6 turns in each coil so I go for 5 , I know some engines that I have rewind has for example 10,5 turn in each coil , you go with maybe 4 parralelle wires and 2 off them go 10 turn and 2 11turn maybe this is a way to fine tune the KV rating?
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
