Brushed/Brushless motors, speed controls, gear drives Discuss all aspects of brushless motors, brushed motors, speed controls (ESC's), gear drives and propellers in this forum.
brushless motor
Old 10-31-2010, 10:27 AM
Default brushless motor
who is the maker of this motor ???? I need the prop adapter the seller of the plane doesnot supply it CAN ANYONE HELP ME?? the three holes are about .491 inches between centers if that is a help no name on motor 35mm dia.
Old 10-31-2010, 11:48 AM
Default RE: brushless motor
In fact you do not need to care that much who makes it. It is enough if it is in good shape from outside and doesn't smell burned. What I would do
is to get one controller from whatever brushless motor, supply half of the max pemited voltage and try to see if this runs and especially how hot
it gets. Anyway, someone nearby who is experienced maybe able to help you in 5 minutes. All those motors are quite the same; the difference
comes from the quality of the materials used(magnets etc). Good luck, Nick.
Old 10-31-2010, 12:27 PM
Unfortunately they don't give the hole spacing but at least these are 3-hole: http://www.electricwingman.com/power...cessories.aspx
It won't be the 22xx (my AXI 2212/34 has holes about 10.35mm apart), but your ~12.5mm might match the 28xx. http://www.hobbyking.com/hobbycity/s...idProduct=6880
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
