Brushed/Brushless motors, speed controls, gear drives Discuss all aspects of brushless motors, brushed motors, speed controls (ESC's), gear drives and propellers in this forum.
brushless inrunner
Old 10-31-2010, 02:10 PM
Default brushless inrunner
Is it possible that running an inrunner brushless motor, without the fan blade, on a edf, would cause it to fly apart on the inside????
Old 11-01-2010, 07:06 AM
whitecrest's Avatar
Default RE: brushless inrunner
Welcome to the forum!
I suppose anything is possible. I think inrunners are rated for very high RPM usually, and you should be able to run it without the fan with no problems. However, I wouldn't exceed its recommended input voltage and only run unloaded for a few seconds at a time to minimize the risk of mechanical failure. You should only need a few seconds for measurements and testing. Otherwise, I can't see the need to run the motor unloaded for extended periods of time.
Old 11-01-2010, 05:35 PM
Thanks for the infomation, Whitecrest.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
