Brushed/Brushless motors, speed controls, gear drives Discuss all aspects of brushless motors, brushed motors, speed controls (ESC's), gear drives and propellers in this forum.
4mm prop adapter
Old 11-13-2010, 11:07 AM
Default 4mm prop adapter
Does anybody know who makes a 4mm prop adapter(collet style) that the threads are longer that what I got? I have the E-flite one and I don`t have enough threads for the spinner and the prop..All the ones I come across seem to be the same short style.....thx
Old 11-13-2010, 03:38 PM
Default RE: 4mm prop adapter
Check this out: http://www.newcreations-rc.com/Produ...umber=HLAN2414
But it is set-screw type, not collet.
Old 11-14-2010, 05:32 AM
thx....I`ll call them up and see if they have a collet one that is the longer style...I like the one with the flats for a wrench on it....Jason
Old 11-17-2010, 10:55 AM
Glacier Girl's Avatar
mazjag, I used to run into this very problem and here's how I corrected it.
Instead of mounting the spinner back plate in front of the collet base and behind the prop, I drilled out the spinner back plate to fit BEHIND the back of the collet collar.
That way the prop fit as intended, the spinner then bolted/screwed to it base plate. You may need to cut the slots in the spinner a little deeper to allow it to slip back further on the prop.
Here, like this.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
