Motor suggestions for 3D
I have a kit similar to the AirWave Sukhoi. The fella I bought it from suggested a Hacker B20 15L. Is there an equivalent motor set up that is alittle easier to find? I have looked at maybe an Astro 020 geared 4.4:1? I have KAN 950's to power it with and want to have plenty of power for 3D flying.
Yes, the Astro Flight 020 geared is very equivalent but they can be purchased many places like Tower Hobbies.
The Kan 950s should work nicely with it but when you are ready for a weight reduction try a 3s3p Kokam 1020SHC 11.1v pack from Bishop Power Products. It has a 1020mAh capacity and can deliver 20amps continuous at only 3oz in weight!
Good luck!
Good luck!
