Brushed/Brushless motors, speed controls, gear drives Discuss all aspects of brushless motors, brushed motors, speed controls (ESC's), gear drives and propellers in this forum.
electrifly .46 specs??
Old 10-04-2011, 04:16 PM
My Feedback: (18)
James c harrell's Avatar
Default electrifly .46 specs??
I picked up a electrifly .46 outrunner but can't seem to find any specs on it. The numbers on the motor say HCAG 3129 it is 42mm Dia, 40 mm length. with a 5mm shaft. Any one have any info?
Old 10-04-2011, 04:46 PM
Default RE: electrifly .46 specs??
Great Planes ElectriFly RimFire .46
42-60-800 Brushless Outrunner Electric Motor.
FEATURES: For Sport airplanes up to 7.5lbs (3400g) and 3D airplanes up to
5lbs (2210g)
Designed for explosive acceleration and maximum torque eliminating
the need for a gearbox
Lightened aluminum can houses high torque rare earth Neodymium
magnets
Double shielded bearings
Virtually maintenance-free; no commutators or brushes to wear out
Two year quality guarantee
INCLUDES: Great Planes ElectriFly RimFire .46 42-60-800 Brushless Outrunner
Electric Motor
Outrunner Motor Mount GPMG1205
Outrunner Prop Adapter GPMQ4906
REQUIRES: Brushless Motor-compatible 60A Electronic Speed Control
Propeller: Depending on aircraft application
SPECS: Motor Diameter: 1.65"" (42mm)
Motor Length: 2.36"" (60mm)
Shaft Diameter: .20"" (5mm)
Shaft Length: .67"" (17mm)
Lead Length: 3"" (76mm)
Connectors: Bullet type" 4.0mm diameter
Max. Constant Current: 60A
Max. Surge Current: 100A
Max. Constant Watts: 1110W
Burst Watts: 1850W
No Load Current: 4.6A
Input Voltage: 18.5-22.2V (5-6S LiPo)
RPM/V (kV Rating): 800
Weight: 9.5oz (268g)
Suggested Propeller Size: 10 x 5E-11 x 5E
COMMENTS: The three-number designation refers to Motor Diameter Motor Length
and kV Rating.
Don't believe everything they tell you... at 3W/g this 268g motor should be rated for only 800W... their ridiculously optimistic 1110W constant/1850W burst will only produce an immersion heater for your coffee!
Old 10-04-2011, 04:54 PM
My Feedback: (18)
Maybe you will tell me straight. I am planning on useing this on a 47.5 in wingspan canard that weighs 48 oz. with a 100 A ESC and a 4s lipo. 9-6 to 10-6 prop. Am I fixin to burn something?
Old 10-05-2011, 05:52 PM
It all depends on what the amp draw turns out to be... IMHO anything more than 60A on 4s might be pushing it.
Old 06-16-2015, 07:12 AM
The hobbico HCAG 3129 is not the same as a RIMFIRE .46. The motor dimensions of the 3129 are different. The closest I think is a RIMFIRE .32 which is a 42-50-800.
Michael
Old 06-20-2015, 03:44 PM
At first glance, I "think" it will be ok but you still should run it through a wattmeter or check amp draw with those props. Running it to 100 amps sells new motors.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
