Using LiPoly with Master 11 3P
I have a Hacker C50-14XL and a Master 77 speed control which is destined to go into a 2m Funtana. I want to use LiPoly but the Master 77 isn't setup to for the LiPoly minimum voltage cutoff.
Is there anything you can get that will warn you during flight that you are getting close to the minimum voltage for the LiPoly?
My Feedback: (21)
I know there is at least one device that can be mounted externally to the airplane that will indicate the voltage. It's a high-intensity LED or something similar. Hopefully, I'll spark a memory in somebody here and they can provide more information.
