Brushed/Brushless motors, speed controls, gear drives Discuss all aspects of brushless motors, brushed motors, speed controls (ESC's), gear drives and propellers in this forum.
Need help with wire codes on brushless motor?
Old 08-24-2003, 09:53 PM
FASTBUICK
Default Need help with wire codes on brushless motor?
Hi If someone could email me the wire code on a Mega motor I need it badly I am putting together a Silentdream for a clubmember and don't know which wires from the esc get soldered to what termianl on the motor. The motor is a Mega 16/15/4 and has no wires attached just wire lugs. the esc is a Phoenix 25 with red/white/black coming out of it for wire colors. the motor has 3 lugs that are next to each other and would love some help on which wire goes where so I can solder them up for him. If anyone can email me or PM me with the color coding that would be great.
Thanks Jerry
Old 08-25-2003, 01:03 AM
kenken
This is a three phase motor. solder one wire on any terminal. touch the other two to the remaining two terminals to check for direction. You change the direction by changing any two wires. You can do this with a couple of cells , that way you will be able to handle the torque. The color of the wires does not matter, you just hook them up to get the proper direction.
Old 08-25-2003, 01:12 AM
FASTBUICK
Default Wire Help
Thank you, Thank you, Thank you !
