Brushed/Brushless motors, speed controls, gear drives Discuss all aspects of brushless motors, brushed motors, speed controls (ESC's), gear drives and propellers in this forum.
Re-using Zagi motor
Old 01-15-2012, 02:31 PM
OIL CAN DAN
Default Re-using Zagi motor
I am planning on building a fixed foam winged airplane with rudder and elevator only and reusing the old Zagi esc (20), and motor but I remember that You can't turn a glow pusher into a "puller" but is it OK to place the electric motor in the front if I change the prop?
Old 01-15-2012, 06:06 PM
jzrf6c
Default RE: Re-using Zagi motor
Is the motor brushed or brushless? What is the weight of the new fomie?
Old 01-15-2012, 11:23 PM
OIL CAN DAN
I plan on keeping the weight the same as or even lighter than the Zagi 16 oz without the battery pack. It is a brushed motor but there are no markings on it as to size or amps. Am I OK turning the motor to the front?
Old 01-16-2012, 05:26 PM
Dr Kiwi
If the CG is okay, then there is no reason why you can't fit the motor in the nose.
Old 01-16-2012, 05:58 PM
OIL CAN DAN
Unfortunately I am still using the old Ni-Cad battery pack and the CG is instantly variable with a little velcro fastening! I'm glad to hear that reversing the motors pull/push direction wont add to the "wear out" time. I'm not very good at posting pics but I'll try to get You one, once I cut the wings and fuse. Thanks for the info. Dan
Old 01-18-2012, 08:11 AM
Handiman
That motor is a Speed 400 size motor. Or most of the older Zagi are that. Be sure to keep oil on the bearings.
It cost about $10 max and you throw away after the brushs are worn out.
Once you are up and flying it is worth it to replace with a better motor with bearings. It will be more effiecient so your flight times will be extended and less heat in all of your electronics.
The better replacment will run you $20-$25 but will last much longer.
Good Luck and have fun.
Copyright © 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
