Replace Motor Shaft
FL
I posted this on the Electric Training section as well.
OK, I have 2 motors that I want to replace a bent shaft on, #1 Rimfire .32, #2 Eflite Bl25.
Both motors have a hex key set screw that is not a 1.5mm (too small) and it is not 2mm (too large). I have searched for a 1.75mm hex key or something in between 1.5 and 2.0mm without success.
Is this some special size that is only available to the manufacturers or am I missing something here?
I have searched some of the other threads on the internet and it seems the Heli guys have the same problem with paddle screws.
I have already stripped out the socket on the Eflite by trying to use a 1.5mm hex, I did not use the ball end either because of the sloppy fit.
I spoke with Horizon about this to see if I could send in the motor and have them replace the shaft, they informed me that tthey did not do repairs on motors and that basically it is a disposable item.
Anyone know whats going on or is that basically it, disposable?
oh for sure on the quality.
I am one of those guys that live under the eyeloop. 36 years in Automatic Screw Machines so I have a habit
of grabbing my micrometer to check the allen wrench. I find acuracy depends on the country. lol amazing huh?
