Brushed/Brushless motors, speed controls, gear drives Discuss all aspects of brushless motors, brushed motors, speed controls (ESC's), gear drives and propellers in this forum.
Kontronik Jazz 63v Program card
Old 09-04-2014, 11:59 PM
Mark Vandervelden
Mark Vandervelden's Avatar
Default Kontronik Power Jazz 63v Program card?
Hi all
I have two Power Jazz 63v ESCs that I had used some time ago, one in a large EDF and the other in a Hele but both have sat in a draw since. One of them has now been fitted into a converted "50cc" Extra along with a large out runner motor and will be powerd by a 12s lipo pack. Unfortunately I have no accurate memory of how these Jazz ESC had been programed but know at least one is set up in hele mode and poss the other with low timing to suit a Nue in-runner in the 120mm EDF. To be safe I have now purchased a 9305 Programing card to both check and adjust them if needed.
"My problem is when I connect up the program card all its LEDs light up for a second and then just all quickly go out again?."
I have tried using the card with motor both connected and disconnected to the ESC .
I have tried connecting the card to a powered RX and then with a RX battery connected to the card alone.
Also with the main 12s battery connected to the ESC and also wile disconnected all with this same result.
I have tried both ESCs in all combination's but have now ran out of options.
Both ESCs are working fine , one on its EDF inrunner and the other set to Hele governor mode but dare not try ether on the large out runner.
Just were could I be going wrong?
Thanks in advance for any incite, Mark V
Old 09-14-2014, 12:47 AM
Mark Vandervelden
Hi Guys, there are guys reading this forum?
Unfortunately I still have no answers to this problem with the Power Jazz/ Program card issue.
I am also extremely disappointed with Kontroniks lack of response to my emails sent over the last two weeks ago.
Although these 400+ ESCs are now out of production I did expect some sort of support from them.
Copyright © 2022 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
