Brushed/Brushless motors, speed controls, gear drives Discuss all aspects of brushless motors, brushed motors, speed controls (ESC's), gear drives and propellers in this forum.
esc help
Old 08-20-2015, 12:57 PM
Default esc help
Can anybody identify this sec please, I need to turn the brake off. It may be from Hobbyking 200amp?
ID:	2115750   Click image for larger version
Old 08-20-2015, 11:28 PM
whitecrest's Avatar
Hard to say what it is from the pictures. You may be stuck if you don't have the programming instructions.
I recall toggling the brake off on an old Tower Pro Mag 8 while at the field by inadvertantly entering programming mode and immediately exiting without making any other changes. I toggled it back on by doing the same thing intentionally. Programming mode is frequently accessed by connecting the battery with the throttle stick fully advanced and exited by returning the throttle stick to zero. (Take the prop off if you try this.)
Old 08-21-2015, 02:25 AM
Is here a programming convention for the order in which things are accessed with escs?
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
