Jetibox “Auto” Setting
Hi Everyone. Thanks to all who respond.
What are the ramifications of using the “Auto” setting vs “Manual” when programming a Jeti Spin 99 Opto with the Jetibox?
I can find no information on the timing advance of the motor I’m using (Tacon Bigfoot 160) so, I thought it might be better to use the Auto function to program the ESC.
thanks
thanks
If it runs smooth through-out the throttle range at Auto setting, stick with it. Timing-wise, I personaly set mine as low as possible in most cases, it's easier on motor, speedy, etc. unless the specs highly recommend higher timing for the particular motor brand.
Best way is to experiment, at what setting it runs smooth if you decide to program it manually.
