equivalent motor
Hi all,
How can I know which motor is equivalent to other one, there are any page or list of electric motor equivalences, for example a Hacker B20-12L+4:1 which others motor can do the same job.
Thenk you,
Luis
Thenk you,
Luis
Hi All:
Hey Spit i'm looking for the same info as you for equivalent motors. Here is what i got.
speed 400 = endoplasma , magnetic mayhem , Trinity speed gems - ruby , sapphire, quartz. These motors are used in the R/C cars and can be used in airplanes. Don't forget the higher the windings the higher RPM's
so look for windings in the 17-24 wind range.Also these motors are being used with a 4.1 ratio gearbox. If you have info I need equivalents for 280, 300 series motors.
Wyld Weasel
Wyld Weasel
for the least money - the Himax 2015 series -these guys are hard to beat --50 bucks . and a adapter kit is 6 bucks same shaft size also --
if you pick a cooler wind - the cost of th brusshless controller can also be lower ( a 10 amp type)
the Hacker and the Himax are the same size cans - in short and long configurations -- (20/20s)
the difference is in the shaft diameters . 2mm Himax/2.3 mm Hacker .
It is obvious that the Himax is made to be a drop in where Hacker is/was fitted.
Hi All:
Hey CThumbs check out hobby-lobby do a search for 280,380,400 speed motors they will show you a list of the motors they carry and spec sheet for them.
Wyld Weasel
Wyld Weasel
