eHawk 1400 upgrade
eHawk 1400 upgrade
I am building a Thunder Tiger e Hawk 1400 electric sailplane. The kit came with a 380 brushed motor but I would like to upgrade to a brushless, run by Li Poly batteries to save weight. Any recomendations? Motor type and size, Speed control, prop size, receiver (JR 8103tx) Thanks Ed
TN
RE: eHawk 1400 upgrade
Your 380 with prop etc is going to weigh about 100g. For only 60g you can fit an AXI 2212/34 and get ~20oz thrust from a 10x4.7, on 3s Lipoly, at a current draw (7.7A) still below the rated max of 8A. A Phoenix 10P ESC will allow you to set the LVC at the safe 9v. A Berg 4-channel Rx with positive shift for your JR Tx would be ideal. 3s TP 2100 (130g) will give you more than enough battery [3s 1200 E-tec [84g] might be enough though they are rated for only 6C (7.2A max)]. But both of those sure beat 8-cell KAN 950's (185g). Actually 3s2p Kokam 640SHC would be really good and weigh only 60g! [and they'd give you 8A at only 12.5C and they are rated at 20C]. You could even go to 3s3p Kokam 1080SHC and still only have 90g of batteries on board.
Cheers, Phil
Of course there are any number of other B/L combos which would work too - Nippy Black, PJS and Rotex outrunners; MP Jet, Razor, Himaxx, Astro, Hacker in-runners with gearboxes.
Cheers, Phil
Thanks Phil
This is exactly what I was looking for. I would like to increase the loft time while buying good components that I could use again in a future model. Do you have any preference on brushless motors. I sure like the Hacker motors.
Ed
Ed
TN
I am rapidly becoming a fan of the out-runners - no gearbox hassles or noises, no pinions to slip, no gears to strip! These neat little AXI 22xx/xx's are fantastic and with 3 winds available in each size you can select the right battery and prop for your particular needs very easily.
Here's a photo or three to tempt you! AXI 2208/34 in Stevens Aero ply mount, and comparison with AXI 2808/20
Cheers, Phil
Cheers, Phil
I looked at the AXI out-runners and they do look great. I measured the nose cone area and they will fit in diameter but the way they are wired I am not sure there is room to run the wires. Can you get these wired for rear egress?
What do you think of the small 1215/16 mini AXI and a Pixie 10 esc ?
Thanks Ed
Thanks Ed
TN
You can turn those AXI's around by using the radial adapter: http://www.aircraft-world.com/shopexd.asp?id=1971
The Mini AC would work but you CANNOT, CANNOT, CANNOT use a brushed ESC (Pixie 10) on a brushless motor. In any case you would need a bigger ESC (Phoenix 25P) since that 1215/16 could well pull 12A-15A. If you get the AXI 2208 or 2212 you'll need the Phoenix or other BRUSHLESS ESC.
Cheers, Phil
Cheers, Phil
