GWS A Drive
TX
How many flights are you flying. I know that mine burnt up after like 30 40 flights and I was using a thunder power 7.4V 860 pack with a 5 amp speed control.
TN
I assume you mean an IPS-DX-AXC motor which, like all the IPS motors, is nominally 7.2v. Do you have a heat sink on it? What prop are you using? If it is bigger than 9x4.7 you will be pulling more than 2A through that motor - and IPS motors don't like that for long.
Cheers, Phil
Cheers, Phil
TX
Yes I am running a heat sink, and a 10 47 as recommended on the back of the packaging on the A drive. I am only getting about, 5 or 6 flights of ten min or so each. If I need to "prop down" what should I got to? 9 3 8 47?
Mike
Mike
