Hobby-Lobby Motor specifications
Have done a bit of searching around and cannot locate any on-line specifications as to performance on a Hobby-Lobby motor. Am considering the MODEL MOTORS Mini AC1215/16 with 3:1 gearbox.
Any propeller reccomendations for this?
Any notes as to thrust developed?
And notes as to power consumption?
Wm.
Wm.
I have an AC1215/16 setup that is similar on my [link=http://www.gregcovey.com/aerobati.htm]Aerobatics[/link] page in my Akro Champion.
[ul] [*] AC 1215/16 Speed 280-size brushless motor [*] RTF @ 13oz. [*] 3.46:1 MJ gearbox MJ8009 [*] Jeti JES 18-3P Sensorless brushless ESC[*] APC 9x6 slowflyer prop [*] 9.5 amps @ 5200 RPMs [*] 8-cells of 800mAh 5/4AAA NiMH
[/ul]
[/ul]
WA
I use the RPM and Prop information from Model Motors web site. I put it into this free thrust calculator,
http://freespace.virgin.net/barry.ho.../thrusthp.html , to determine expected thrust. It also gives you thrust to weight ratio and pitch speed in MPH. You can also change the air density to predict performance at different altitudes.
