Mega Motor Help
I have a Mega 16/7/7 attached to GWS gearbox and a CC Phoenix 25 esc and the prop is an APS 9x5e the thing just chatters and won't move. The prop shaft seems free & without the prop attached seems to turn freely. I've tried several fully charged batteries from 12v nimh to 1500mah lipoly 11.1 v and nothing seems to change except the motor starts to get warm as does the esc. The esc indicates full throttle by the flashing red lamp. Any ideas? Do I have a defective motor? Thanks for any help.....Mike J.
Flash-----It's a defective ESC as I switched to another ESC and the Mega brushless is a wow!!motor!! very powerful. I'll call CC as the ESC is new..
My Feedback: (314)
A couple of suggestions. Have you checked the programming of the ESC? Check the instruction sheet for the way to do this. Have you tried reversing your throttle channel?
