Brushed/Brushless motors, speed controls, gear drives Discuss all aspects of brushless motors, brushed motors, speed controls (ESC's), gear drives and propellers in this forum.
ESC question
Old 03-16-2004, 08:22 PM
Beeza
Default ESC question
Hi Guys,
I'm thinking about using a Graupner Speed 280 motor on a foamie project, but my ECS are for speed 400. is there any harm done here?
I'll prob use a small NiMh or nicad.
thanks.
Beeza
Old 03-16-2004, 08:41 PM
bosworthdf
Default RE: ESC question
Weight is the only problem with the use of the larger speed controler. You kneed to know the amp. draw of what ever motor you are useing & the max amp. of the speed controler. If the draw of the motor is equal to max or less of the speed controler your fine. The Astro Whatt-Meter #101 is a great tool to tell stactic draw of any electric motor. Good luck
Old 03-17-2004, 08:08 AM
Matt Kirsch
My Feedback: (21)
Matt Kirsch's Avatar
There is no problem using a speed controller that is too large. You won't hurt anything, and the 1/2 ounce difference in weight probably won't even be noticeable.
