AXI2820 help
My Feedback: (21)
Define "better."
12 cells is too many for the 2820/10. On 10 cells, both motors can be made to perform similarly, with different props of course. The 2820/12 will need a higher pitch and larger diameter prop to get the same thrust and speed.
i would say that it is better to buy the 2820/10 as it is more versatile. It would take 12 cells but better on 10 cells as it gives better thrust to power ratio. it is more verastile because you can use it on 10 or even 8 cells.
I prefer to use the higher Kv version that uses lower cells which reduces weight.
My [link=http://www.gregcovey.com/wipa_firecat.htm]Wipa Firecat[/link] uses a 2820/10 motor.
How do you know what is to much amps/volts for the motor?? I have an AXI as well, I am working on a project and he gives me these AXI motors to try and see how they work.
The reason I asked abt the 2820/10 and 12 was that when I was buying the 2820/10 the sales guy at nesail said that he prefers the 2820/12 as it gives more thrust. So I bought the 2820/12. now I want to know is that does the 2820/12 actually give more thrust than the 2820/10 on 10 cells.
Also, even Id like to know how do you know what is too much amps=volts for the motor.
Keith,
You can view the AXI specifications from the manufacturer [link=http://www.modelmotors.cz/index.php?id=en&nc=produkty_select&id_odkazy=m_ac]here[/link]. The maximum current level is slightly above the max. efficiency current rating. Since it is a grey area that depends upon time and how far above this you go, it is best not to push the motor much beyond specs. unless competing.
fnp,
The answer is no. In fact, on 10-cells, the 2820/10 produces more power than the 2820/12.
Do not confuse this scenario with what NE Sailplanes may have said because on 14-cells, you can't even use the 2810/10 and the 2820/12 has more power output than the 2820/10 can realistically produce.
fnp,
ORIGINAL: Greg Covey
Keith,
fnp,
Keith,
fnp,
Also What do I look at to tell which AXI motor produces more torque. I need more torque and I get AXI motors from a friend (meaning I don't have to pay for the motor, jsut return it when I am done). He orders them direct from the factory. How do I know which AXI motor I need?
I hope what I asked makes sense???? Thanks in advance.
