Multimotored brushless issues
I have a B-25(purchased from Dymond Oshkosh) that is supposed to fly with 2 geared speed 400's. I would like to put 2 Hacker b20-15l's on it. I have read/heard of issues with brushless multi's. Can anyone set me straight with tips/advice? Thanks
TN
As long as you have a separate ESC for each motor you should be fine. Obviously you could even set it up as two completely separate and independent systems (motor/ESC/battery) - why would that differ from the standard set-up?
Cheers, Phil
Cheers, Phil
